Rearview mirror glass or plastic - crack in edge
Cleaning the car and came across a small crack in the edge of the rearview mirror. Feels plastic... can't see a seam between the edge material and main mirror... is it all plastic, all glass? Are cracks a documented issue? Searched with no results. Car is a 2014 purchased used a month ago no more bumper to bumper.
Avanti (12-21-2017)
Received 5,324 Likes
If it bothers you, and it seems it does, it looks like you'll have to buy a new one unless you find someone parting out a wreck... I'd not think that piece would normally be damaged in most mishaps. If you have a half-way with it salvage yard they may be able to locate one for you. Best of luck.
Just trying to understand if anyone knows how the mirror is constructed? It seems like a special acrylic over the whole thing?
Moderator
That's the "frameless" rear view mirror. Comes on the 2LT and 3LT trim levels. Don't know if it is glass or acrylic.
First report I've seen of one being cracked.
My 3LT's rim is abraided.
Look where my finger is pointing in photo below.
The chrome-look acrylic frame around the mirror, may have had the chrome scratched/removed off of it.
Mine's perimeter is good, though.
RapidC84B (12-22-2017)
Looking closer it appears to be a thin clear acrylic frame around the glass. The blemish is on top so can't really see it. Will take care adjusting the mirror.
