C7 indicator problem
Old Feb 8, 2018 | 07:15 PM
Lacroix's Avatar
Lacroix
4th Gear
Default C7 indicator problem
Hi,2016 c7 left hand indicator not working ( inside blinks fast indicating a blown bulb) but same led lights work with
hazard lights, any ideas what problem would be, thanks mike
Old Feb 8, 2018 | 07:26 PM
spearfish25's Avatar
spearfish25
Probably not ZR1 specific.
Check fuses?
Old Feb 9, 2018 | 01:00 AM
Thomas Hays's Avatar
Thomas Hays
Cruising
Default Same problem x
Same dam problem
Old Feb 9, 2018 | 09:27 AM
DebRedZR1's Avatar
DebRedZR1
Moderator
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'17, '21
Moving to C7 General
Old Feb 9, 2018 | 05:03 PM
Avanti's Avatar
Avanti
If connectors check out okay, try replacing the LEDs anyway. Also, without an electrical schematic I'm guessing, but may still have a flasher somewhere?
Old Feb 9, 2018 | 05:11 PM
ojm's Avatar
ojm
on my past cars if bulbs ok was flasher if not flasher then switch on steering column, good chance a vidio on Youtube.
Old Feb 9, 2018 | 08:41 PM
charliebrown266's Avatar
charliebrown266
no bulbs in the C7! all LED if the working on the outside my guess is the module mounted under the headlight assembly! is the info center saying there is a problem?
Old Feb 11, 2018 | 01:59 PM
Lacroix's Avatar
Lacroix
4th Gear
Hi,hoping it has nothing to do with lights or module on light assembly as to get to lights on c7 the whole front of car has to come off ( keeping my fingers crossed)
Old Feb 27, 2018 | 10:15 PM
Lacroix's Avatar
Lacroix
4th Gear
Hi, update on left hand indicator not working had vechicle checked by auto electrician on there scanner seems to point
to faulty wiring or module back on light it self. Which means front of c7 has to come off to get to lights.
should I try this myself guys or leave for experts, any suggestions .
Old Feb 28, 2018 | 12:43 PM
charliebrown266
Its not that hard to take the front bumper off! there are very good how to in the sticky section
Old Feb 28, 2018 | 01:19 PM
Rebel Yell's Avatar
Rebel Yell
If it's still under warranty I would take it to the dealer. The bumper may be easy to remove, but only if you have the tools and know how. Good luck.
Old Feb 28, 2018 | 01:20 PM
davepl's Avatar
davepl
I'd take it to the dealer as these are now lifetime service LEDs and in some cases (like the third brake light) are not designed to be serviced or accessed by the end user.
To C7 indicator problem
