Oops - another jack failure
Old Feb 10, 2018 | 11:46 PM
owc6's Avatar
owc6
Are you planning on pulling them off your old car and installing them on your new one?
;P
That's what I would do!
Old Feb 10, 2018 | 11:51 PM
Foosh's Avatar
Foosh
Was that for me? If so, yes, that's what I did. I picked up the new car on Thursday.
Old Feb 10, 2018 | 11:58 PM
owc6's Avatar
owc6
Yes, I've been chastised for using my sig too often and quoting too much. so now when I reply it often makes no sense.
So exciting for you! I will admit I am a bit jealous.
Old Feb 11, 2018 | 12:01 AM
robertbruce's Avatar
robertbruce
Made me stop and think.I am always jacking up my Corvette when I have to pull a tire.
Old Feb 11, 2018 | 12:04 AM
Maxie2U's Avatar
Maxie2U
Originally Posted by BlueDevilZ51
This is what you have car insurance for.
Car insurance covers this type of thing?
Old Feb 11, 2018 | 12:11 AM
Foosh's Avatar
Foosh
[Sorry for the hijack]
Thanks Lisa, story here. Stop by sometime soon.
https://www.corvetteforum.com/forums...range-c7s.html
Old Feb 11, 2018 | 12:19 AM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
It should.
Old Feb 11, 2018 | 12:45 AM
Steve_R's Avatar
Steve_R
That’s one of the reasons I’m not in the C7 forums much any more. It’s unfortunate.
Old Feb 11, 2018 | 01:15 AM
hangman's Avatar
hangman
Just claim with your insurance and just pay the deductible and be done with it. Why shell out money to fix yourself? You pay the insurance company good money, now use them to get your car fixed.
Old Feb 11, 2018 | 01:26 AM
Godsvett's Avatar
Godsvett
Veteran: Marine Corps
Congrats on the new vette Foosh! Pics?
Old Feb 11, 2018 | 01:34 AM
Foosh's Avatar
Foosh
Thanks, and yes many here.
Old Feb 11, 2018 | 02:12 AM
Pappa Bear's Avatar
Pappa Bear
Cruising
So I have USAA covering the vehicle and when I called them the guy said it would not be covered. I am certainly not above using insurance to fix it but if what that rep said is true I’m SOL. I would hope that something like this would be covered.
Old Feb 11, 2018 | 02:15 AM
  #33
Foosh's Avatar
Foosh
I was surprised that others said insurance should cover it. I've never seen a policy that covered DIY maintenance accidents.
Old Feb 11, 2018 | 02:20 AM
  #34
KnightmareCS's Avatar
KnightmareCS
Just say you ran something over...
Old Feb 11, 2018 | 07:20 AM
  #35
Flame Red's Avatar
Flame Red
OUCH! You know, sometimes $hit happens. You did a great service to the foum by posting this as we all need periodic reminders of safety. Maybe you saved someone here. Sorry to see those pictures. At least it did not fall on you. The car can be repaired. You are not the first to have this occur, reference vettes that fell off lifts. Expensive lesson, but it is only $. A funeral would be much more expensive. Consider yourself fortunate that the firemen did not have to come to get you out from underneath the car with you legs twitching in a pool of blood...
Old Feb 11, 2018 | 07:26 AM
  #36
Walt White Coupe's Avatar
Walt White Coupe
Along those lines, and not intended for you, just general info, the leave-in hard plastic jacking pucks are less than $50, and coupled with a proper floor jack with rubber lifting pad, make it virtually impossible for a vehicle to fall off the jack.
100%
The metal pucks that are being sold look to me like an accident just waiting to happen. They are just too slippery. The hard plastic jacking pucks that I used were actually BMW pucks that snap into the frame holes and are permanent installation. They fit my C6 and I removed them and are now in my C7.
Old Feb 11, 2018 | 07:34 AM
  #37
Millerrock's Avatar
Millerrock
I don’t why people try to save a buck
To Oops - another jack failure
Old Feb 11, 2018 | 07:50 AM
  #38
449er's Avatar
449er
CF Community Team
You can jack up a Corvette safely every time IF you follow the right procedure. You MUST use jacking pucks, make sure that the jack contacts them properly & you need to be on a level surface, Don't use 2x4s or anything else other than a jacking puck. To the OP, Don't try to repair the damage yourself unless you have significant body work experience, you will make a mess out it
Old Feb 11, 2018 | 07:58 AM
  #39
DALE#3's Avatar
DALE#3
Holy Crap..Car can be fixed.Looking at the brightside,your ok.
Old Feb 11, 2018 | 09:43 AM
  #40
Kevin A Jones's Avatar
Kevin A Jones
That's very surprising. What was their reason for not covering it?
Originally Posted by Walt White Coupe
100%
Too slippery as opposed to hard plastic; that's non-sense.
As long as proper jack and safety precautions are used, both are safe.
As seen below the steel puck 'seats' into the steel jack cradle walls by almost 1/4" eliminating risk of slipping out unless C7 is being jacked on an un-level surface or jack wheels are locked not allowing the jack to slide as being pulled in slightly as C7 is lifted.
These safety malfunctions would cause the same risk whether steel or plastic pucks are being used. Actually, if there's any risk of puck failure, it would be the hard plastic puck cracking under extreme pressure.
