Toe Hook Capability
Old Mar 16, 2018 | 09:13 AM
redGS12's Avatar
redGS12
Default Toe Hook Capability
Don't track my Grand Sport but have been looking at toe hooks as a source for tie off point to use in a case where mechanical failure calls for the need of a wrecker. Anyone know if they are rated to be used for pulling that much load up a tilted flat bed wrecker.
Old Mar 16, 2018 | 09:45 AM
p3pilot's Avatar
p3pilot
https://www.corvetteforum.com/forums...-tow-hook.html
Old Mar 16, 2018 | 10:10 AM
redGS12's Avatar
redGS12
Thank you. I was pretty sure they would not work for this application but just thought I would solicit the site for info.
Old Mar 16, 2018 | 05:04 PM
BEZ06's Avatar
BEZ06
TOE hook:
TOW hook:
Old Mar 16, 2018 | 07:07 PM
Racingswh's Avatar
Racingswh
I have seen it done and boy did it look scary to me. Like if it let go the result might be something you might see in a scene from Final Destination for anyone standing close to the wire. Why they didn't use J hooks in the chassis I do not know.
Old Mar 16, 2018 | 07:15 PM
bankers1's Avatar
bankers1
So, Am I to be worried? I just bought one of those nice looking Red color, in a velvet, see through box, $ 150+, tow hooks at vettemods.???? All show? or will it work?
Old Mar 16, 2018 | 07:27 PM
Racingswh's Avatar
Racingswh
Work for what? If you're talking about pulling up onto a tilting trailer I would just use the J hooks secured into the chassis holes and a proper tow strap. I would not use the front or rear tow hook to load the car on this.
Tow hooks are for pulling the car out of the sand or gravel trap at the track or when the car has a mechanical failure and needs to be towed back to the paddock.
So if I were really thinking about serviceability on a street car I would buy two J hooks and a tow strap and keep it all in the rear cubby. That way if there was ever an issue and the car needed to be winched onto a tilted flatbed you would have exactly what you need to do that.
Old Mar 16, 2018 | 11:58 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I keep a pair of the T-hooks that fit into the frame, in my rear cubby, in case the car needs to be put on a flatbed.
If you go into a ditch or get stuck in mud/gravel/snow/etc, the frame slots may be buried and the "official" tow hook would be needed.
I swallowed hard, paid the outrageous price (even with a good discount) for the factory version, and keep it stored in the slot near the battery. Before buying, verify that your car actually has the threaded hook receivers!
After doing all that, I'll never need it...
Old Mar 17, 2018 | 09:28 AM
Boiler_81's Avatar
Boiler_81
The OP's car will have receivers. All Grand Sports have the receiver. Also all Z06s and Z51s built after about Dec 1 of 14. Base cars do not have them.
Old Mar 17, 2018 | 01:16 PM
SD_Dave's Avatar
SD_Dave
Dr. Dave
Originally Posted by BEZ06
TOE hook:
TOW hook:
To Toe Hook Capability
