Trailer tie downs for C7
Old Mar 27, 2018 | 01:50 PM
Skylane765's Avatar
Skylane765
Supporting Vendor
Default Trailer tie downs for C7
We now have our new strap points for the Corvette C7, they are made of cold rolled 1/4 inch steel powder coated red. Comes in set of 4 for front and rear. They do not interfere with ground clearance. MADE IN USA See at. https://zl1addons.com/collections/co...e-strap-points
www.zl1addons.com
Old Mar 27, 2018 | 05:31 PM
Borntorun04/17's Avatar
Borntorun04/17
I have ZLI Addons jacking pucks they make quality stuff!
Old Apr 14, 2018 | 08:34 PM
Johnp94's Avatar
Johnp94
Bump for the pictures, I ordered these.
Old Apr 17, 2018 | 09:30 PM
Johnp94's Avatar
Johnp94
Easy to install. 15 mm ratchet for the fronts 18 mm ratchet for the backs. Real excited to have these.
Old Apr 18, 2018 | 06:23 PM
Mick14's Avatar
Mick14
What is everyone's opinion on these? Will these work ok to tie down on an enclosed trailer. I have read on towing publications to never tie down to any aluminum components on c7's. Could this effect alignment at all?
Old Apr 18, 2018 | 08:13 PM
Kevin A Jones's Avatar
Kevin A Jones
Same thing I was thinking, why not just use the slots at the jacking points?
Old Apr 22, 2018 | 12:08 AM
mdolandese's Avatar
mdolandese
Old Apr 22, 2018 | 01:07 AM
GordyS's Avatar
GordyS
Arent the tie down points made out of aluminum? I tie the front of my Z06 with straps over the tires and cross strap the rear with straps over the wishbones on the rear suspension. May change the rear to mimic the front-this allows body to float and yet securely ties car to trailer.
Old Apr 22, 2018 | 02:06 AM
Kevin A Jones
Quite a bit of difference from a structural perspective from tying into a tie-down slot in a high grade aluminium frame rail using a "T" hook as opposed to utilizing a bracket bolted into a random aluminium component.
Old Feb 23, 2025 | 11:01 AM
Cockyvette's Avatar
Cockyvette
1st Gear
I know this is an older thread. Did you torque them and how are they holding up? Thanks in advance!!
To Trailer tie downs for C7
