Thank You Range Technology !
Old May 23, 2018 | 11:26 AM
36couper's Avatar
36couper
If I run in Manual mode, does the AFM still kick in?
Old May 23, 2018 | 11:27 AM
Dcasole's Avatar
Dcasole
Originally Posted by DAVE396LT1
Does the most up to date version still kill the battery or have they fixed that?
Guys were running ALDL cables with relays and switches to work around it, but I don't want to work that hard. If they've sorted out their power supply issues and have solved it so it doesn't kill batteries, I will buy one. If they haven't, I won't.
Anyone know for sure?
May car has the latest version and sat in the garage for over a week last week because of really bad storms , had no problems starting it ( original 3 year old battery )
Dave
Old May 23, 2018 | 11:28 AM
Dcasole's Avatar
Dcasole
Nope , only in auto mode
Old May 23, 2018 | 02:23 PM
bjones7131's Avatar
bjones7131
Default Range and M7
The manual M7 stick shift will go into V4 mode only if you select ECO mode via the **** on console. A8 should have this same feature w/o using paddle shift in M mode.
Old May 23, 2018 | 02:53 PM
Bigfoot16's Avatar
Bigfoot16
I can only go by having mine a few days. So far no problem. It has been stated on here the issue has been resolved.
Old May 23, 2018 | 09:04 PM
cowboy casey's Avatar
cowboy casey
they say (read it on here from Range Cust Service) the battery drain issue is fixed even though it really was not a problem unless your car sits for weeks without driving it... I think the alarm pulls more power than the range device did..
Old May 23, 2018 | 09:18 PM
Kevin A Jones's Avatar
Kevin A Jones
Fixed, at least I'm perfectly satisfied it is and I'm a show me type individual whose not easily convinced on this type thing.
Old May 25, 2018 | 10:30 AM
flynbulldog's Avatar
flynbulldog
C7 of Year Finalist (stock) 2019
Originally Posted by Dcasole
Yes autos run know 4 cylinder mode during certain cruise conditions , to save fuel
this switching back and forth between 8 cylinder and 4 cylinder modes caused issues with the lockup torque converter in A8 cars ..
I don't know about you I did not buy a corvette for its gas mileage and I sure as heck to not want my torque converter lookup feature to cause issues .....
AFM is not ready for prime time , just look at the problems it is causing in the other GM lines and models
Dave
So this is not a factor on manual transmission cars?
Old May 25, 2018 | 10:45 AM
davepl's Avatar
davepl
So to be a bit pedantic about it, it doesn't kill your battery any faster?
Old May 25, 2018 | 11:04 AM
Dcasole's Avatar
Dcasole
"causing issues with the lockup torque converter in A8 cars .. "
Dave
Old May 25, 2018 | 11:06 AM
Dcasole's Avatar
Dcasole
Leave a corvette or any newer car in an idle state for to long and you will come out to a dead battery …….
Like I said above , I have the latest firmware and my car has sat for 3 weeks because of work schedule and heavy storms , it kicked right over and my battery is 3 years old
Dave
Old May 25, 2018 | 11:14 AM
davepl's Avatar
davepl
3 weeks works for me!
