TC replacement
Old Apr 15, 2018 | 06:12 AM
jim spitzer's Avatar
jim spitzer
St. Jude Donor '12
Default TC replacement
My car is going in for the TC replacement, I understand that a lot of the back end of the car comes apart to do this job. My question is does the dealer have to remove the fuel tanks when this job is done? I didnt want to top off the car if the tanks need to be removed?
Old Apr 15, 2018 | 09:47 AM
TEXHAWK0's Avatar
TEXHAWK0
Why would you even think about taking car for repair with full tanks?
What is TC? Traction control?
Old Apr 15, 2018 | 10:13 AM
nikic6's Avatar
nikic6
OK I give up. What is a TC?
Old Apr 15, 2018 | 10:38 AM
PatternDayTrader's Avatar
PatternDayTrader
Torque Converter.
Old Apr 15, 2018 | 10:40 AM
PatternDayTrader
Just make sure theres adequate fuel in it for a proper road test before and after the work is done.
Old Apr 15, 2018 | 12:00 PM
TEXHAWK0's Avatar
TEXHAWK0
Originally Posted by PatternDayTrader
Torque Converter.
It dawned on me he meant torque converter later.. talking about fuel tanks in the rear threw me off..
I think the answer to the question is that the drive train can be removed without taking out the tanks.
Old Apr 15, 2018 | 05:24 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
If they will be doing a ride-height adjustment or alignment, both of those should be done with full fuel.
You can ask them to add ballast weight in the trunk and hope they do it right, or add weight yourself and hope they don't move it.
I'm lazy, I just fill up before that kind of work.
To TC replacement
