Need Jacking pads
Old May 6, 2018 | 05:26 PM
geewez's Avatar
geewez
ZL1addons and Reverse Logic both make a good lifting puck. I use the ZL1 pucks on my Dodges. If you really want a nice puck, check out the machined ones made by Katech. They make a regular one and a higher 2" version for Z06 and Grand Sports to clear the side skirts. A bit pricey but well worth it IMHO.
Old May 6, 2018 | 05:41 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Originally Posted by SouthOCBoy
I'm sorry but I'm not sure what you mean. There are pictures within the link I attached; one of which is a side view of the bottom with the pucks attached. They are not obtrusive with the side skirts and do not hang down very far. They work for me.
What I meant is do they have enough height so that when using the pucks the jack clears the Stage 2 or Stage 3 GM side skirts on the Grand Sport/Z06/ZR1.
Many of the leave in jacking pucks aren't thick enough to work on a C7 with side skirts when using a garage hydraulic jack.
Borntorun04/17's Avatar
Borntorun04/17
I went with ZLI Addons for my GS . Here's a two pic's of them on GS.
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Originally Posted by TEXHAWK0
I would not buy anything plastic that has to support the weight of the car. Eventually they will fail... Our club actually had a local machine shop make up some from aluminum and stainless steel...
For those that don't have access to a machine shop and want metal, KaTech has 2 1/2 inch diameter aluminum jack pads. They come in 1 and 2 inch height. I have both. However unlike the Reverse Logic pads they cannot be bolted in temporally to be assured they will be used by a dealer or tire shop.
KaTech has both 1 and 2 inch high aluminum jack pads for sale.
Old May 6, 2018 | 06:50 PM
geewez's Avatar
geewez
Again-read my post #21.
Old May 6, 2018 | 07:01 PM
Ozzstar's Avatar
Ozzstar
Originally Posted by Thom1986
I have a 2016 C7 Z06, need to purchase jacking pads. Where would be a good source to buy from? Looking for a good set! Thanks for your help!
A video is worth a million words. Hope it helps you out. -Ozz
Old May 6, 2018 | 07:21 PM
MSG C5's Avatar
MSG C5
I saw that, but your post was after I asked about the other leave in pucks from West Coast Corvettes. Based on pics, I don't think any leave in pucks will clear the side skirts. Thanks!
Old May 6, 2018 | 10:26 PM
orca1946's Avatar
orca1946
I had the plastic leave in ones on my C6 and 2 of them fell out after a few months!
Old May 7, 2018 | 12:48 PM
Frankers's Avatar
Frankers
6th Gear
Originally Posted by JerryU
If you want a quality set with a major added advantage (explained below) Reverse Logic has 2 1/2 inch diameter pads GM says should be the max diameter used (I know hickey pucks can work if you push the eye bolt away from the rocker panel!)
Reverse Logic is a Forum vendor. Can be used bolted in or just installed if you are doing the work. Since a Z06 has side skirts may need the 1 inch high pads vs snap in.
https://www.reverselogic.us/corvette_jack_pad.html $65/4 free shipping
Some rocker panels are close to the tie-down slots that others. Hence 2 1/2 max recommendation form GM
ADVANTAGE OF REVERSE LOGIC
If going to a dealer with my C6 I always put my jack pads in a clear plastic bag on the passenger seat and would tell the Service Writer to be sure the tech used them on their 14 center post lifts. But would they?
When I got my 2014 C7 GM sent a notice to have the dif fluid level checked. I said my usual with my aluminum pads on the passenger seat. The Service Writer (who I knew from my C6) said: "Don't worry, I will insist they use our alignment rack (they only have 1) as we just cracked a Vette rocker panel and are having to have it repaired!"
With the Reverse Logic pads you can take them apart with the supplied Allen wrench, then remove the white section and bolt them temporally in the Vette. Drive to the dealer than you are sure they are used! They should be removed after the work is done as the stick down and could hit a speed bump etc.
I keep them in my rear compartment in case of a flat etc. I use them like normal jack pads, insert and then remove when finished jacking!
I bought a set of these largely due to this post. Thanks for the great rundown of the reverse logic pads. I have mine and now keep them in the rear storage too.
Old May 7, 2018 | 01:42 PM
orca1946's Avatar
orca1946
https://zl1addons.com/products/corve...on-jack-points
I like these - they seem to be smoother at the edges for "sliding" over anything that might hit it.
Old May 7, 2018 | 02:07 PM
Superstar555's Avatar
Superstar555
Originally Posted by jimmie jam
These are the BMW's.....
And they are also $7 at Rock Auto.
