C7 Front Grill ????
Old May 11, 2018 | 11:48 AM
joebean's Avatar
joebean
Default C7 Front Grill ????
I have a question that I know one of you guys can answer !! I got a chunk of my grill knocked out by some road debris and I'm trying to order another grill. The question is : if I have front cameras on my 2016 Z51 do I have to order a grill with the front cameras or can I order a grill without the cameras and use my cameras which were not damaged. And If I go with a ZO6 front grill which that's the only one that I could find that was under $200, that they said would fit my car. Have any one of you changed out your grill to a Z06 grill on a Stingray and if so could you post a picture so that I can get a feel of the look on the car. Also if someone have a take off grill for a Z51 that they want to get rid of let me know. Thanks JB
Old May 11, 2018 | 02:18 PM
chronage's Avatar
chronage
If you're buying factory GM parts, then my understanding is you cannot simply swap the cameras over to a non-camera grille. You'll need a grille made for models equipped with it (cameras included in the assembly). I've heard of z06 replica grilles that come with a way to mount the your existing cameras however.
Highly recommend switching to the Z grille since you'll have the bumper off anyway. Looks better and much better airflow.
Old May 11, 2018 | 05:21 PM
sTz's Avatar
sTz
This thread might help: https://www.corvetteforum.com/forums...-and-pics.html
Old May 11, 2018 | 07:48 PM
UsernameProtected's Avatar
UsernameProtected
Yes you can use your cameras with the $189 version of the z06 grille.
Old May 11, 2018 | 10:01 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Check out our version of the z06 grille. You can add our camera bracket kit in the options and reuse the oem cameras.
http://www.jwmotorsportsllc.com/C7-Z...lle_p_342.html
Old May 13, 2018 | 02:44 AM
joebean's Avatar
joebean
Where did you purchase your grill from??
Old May 13, 2018 | 05:17 PM
Pisswilly's Avatar
Pisswilly
Wow! Great price!
Old Jun 16, 2018 | 11:56 PM
joebean's Avatar
joebean
How did you mount the camera plate and bracket ?? we could not figure out how to screw the flat plate on to the grill. It had some screw holes on the plate but no where on the grill that lined up to mount the plate. I could see where to do the cut out for camera wire but got stuck in these flat plates. Will send pictures if that will help you understand my question better. Thanks in Advance !!! JB
Old Jun 17, 2018 | 12:48 AM
UsernameProtected
Sorry, I had a shop do the install on mine, so I can't help there.
To C7 Front Grill ????
