Got the letter
#381
I don't think GM would even spend the time to do that. You're overthinking it.
Engineering tries to the best of its ability to solve a problem, once they do that management decides what to do. Which usually is the quickest fix. Not the most cost effective fix, sometimes quick is expensive.
Design engineers are not perfect designers and mistakes are made. Not every problem, as you seem to believe, is a result of poor quality of a perfect designed part/assembly.
#382
Corvette Enthusiast
There is a difference between good intentioned design, and purposefully bad design. Over time design rules, best practices, and new requirements get generated to prevent issues. But sometimes technology changes, what was a good test and requirement on an iron part doesn't mean it works for aluminum or magnesium.
Plastics are in the same boat.
#383
People aren't perfect. Knowing this you have to prepare that some designs will have issues in the long run.
If anyone is caught "purposefully' doing a bad job, whether it's engineering, production, accounting, etc, then they should be fired on the spot.
#384
Corvette Enthusiast
Originally Posted by JoesC5
Would they be needed if the original design engineers had done their job in the first place?
#385
<snip>
And now we get the boards who will fight you to the death, literally, over faulty ignition switches. The GM "secret" extended fuel tank warranty issued, transferring the onus of responsibility to the owner to detect, diagnose and seek repair of this faultily-produced fuel tank "but don't bother your dealer unless you smell gas fumes or see gas running out from under the car!"; speaks volumes more than anybody's pooh-poohing of the issue.
And GM is doing an absolutely horrible job keeping the extended warranty on the fuel tank a "secret" as you say, since they are sending out letters detailing their "secret" program to every address they had for the target years!
#386
I also received the letter. Mine is a '14 Z51 A6 but haven't noticed any gasoline leak. Hope nothing related happens later on.
#387
I wonder why a good friend of mine, a retired GM Manager of Reliability Engineering, had a job? Would they be needed if the original design engineers had done their job in the first place?
#388
Was going through last month's mail today. I got the letter. I'm a month long traveler and mail doesn't all get opened right when I get home.
Coverage to; "10 years from in service date, or 120,000 miles." I'm good with that. I'll likely buy the GM Extended Warranty B2B plan at some point, and should maybe sell the car by the time 10 years elapses. I do love this C7 M7 convertible!
#391
Received 1,738 Likes
St. Jude Donor '15-'16,'18
Yep, the lawyers are big time CYA.
#392
I sure understand that this is unnerving to those effected. Right now, I am only seeing some 2016 owners effected from above posts. Anyone with other than a 2016 who got the letter, and/or went on line and found out their another-year C7 is effected, please post up here for the rest of us.
Thank you.
Thank you.
#393
So this is a rare failure is that right? Only happens to a small %?
So I guess pay attention and look out for gas smells I guess, gas leak on the floor, and check engine light?
But very serious problem if it happens ? heard many said "time bomb" "gas bomb in garage" etc
#394
#395
LOL interesting story thanks for that. I guess don't worry too much but always pay attention.
#397
Sad to see that C7 vette fuel tanks at the top pump mounting area are cracking much like so many of the C6 did. Never a problem after 11 years with my 07 vert, 5 years with the 06Z and now well over 7 years with the ZR1. However my son did after 4 years with his 08 coupe. Fortunately covered by warranty. The C6 driver side tank pump discharge plastic elbow fittings were prone to cracking I suspect due to inferior plastic grade materials.
#398
#400
^ If it was corrected, it happened either by the time the 2018s were released or sometime very late in the 2017 run. This thread and distribution of letters has been going on for awhile now, and I've yet to receive one. The warranty has also not appeared on my "MyChevrolet" dashboard.
