Windshield Washer Problems
Old Jun 5, 2018 | 01:10 PM
nightroddersp's Avatar
nightroddersp
Default Windshield Washer Problems
My damn window washer pump went out some time between my ME last month and going to work. Got a huge bug spatter on the windshield and count clean it, had to stop at a station. I told the service person. I Checked there is fluid in the res., fuse is good, and there is no noise coming fro the little pump.
Old Jun 5, 2018 | 01:19 PM
RonC7's Avatar
RonC7
See this previous thread:
https://www.corvetteforum.com/forums...pump-inop.html
Ron
Old Jun 5, 2018 | 01:30 PM
TEXHAWK0's Avatar
TEXHAWK0
I would just remove the front wheel well liner and pull the pump out of the tank for a test. They are so cheap, you might want to go ahead and order a replacement. Could just be small amount of debris keeping the rotor from turning.
Old Jun 5, 2018 | 02:04 PM
nightroddersp
I put the service call in. I know it's easy to replace but if its under warranty then I will let them fix it. I went 13 years before having to replace the 2002 suburbans rear washer motor. I just replaced the front washer motor assembly after my battery leaked and kill the res and the front motor assembly, luckily I didn't have to replace rear one the acid went around it.
Old Jun 18, 2018 | 02:39 PM
nightroddersp
Got the new windshield washer installed under the warranty. Washes really well now. Dealer did it in about 2 hour, from the time I dropped it off till the time they called and said it was done.
Old Jun 18, 2018 | 03:36 PM
TEXHAWK0's Avatar
TEXHAWK0
So, what was the problem? Was there just something stuck in the washer pump like the other thread?
To Windshield Washer Problems
