Launch control without PTM
Old Jun 11, 2018 | 07:53 PM
subieworx's Avatar
subieworx
Default Launch control without PTM
Getting into launch control mode with a mag ride car is easy, but on my 15 z51 non mag ride car it doesn't seem possible. Is it?
Old Jun 11, 2018 | 09:42 PM
Dcasole's Avatar
Dcasole
Auto or manual ?
Old Jun 11, 2018 | 09:43 PM
subieworx's Avatar
subieworx
Auto
Old Jun 11, 2018 | 09:51 PM
kc stingray's Avatar
kc stingray
set vehicle to track mode, disable traction control and stabilitrak. depress brake pedal hard to the floor and hold. last step mash accelerator pedal to the floor. release brake pedal when ready to launch.
Old Jun 11, 2018 | 09:56 PM
subieworx's Avatar
subieworx
Yeah, doesn't work. It tried to move the car forward as it sits at 1800 rpm stall of the converter
Old Jun 11, 2018 | 11:32 PM
jbrown8238's Avatar
jbrown8238
NE Events Coordinator
Default Launch
You have to hammer the brake like an emergency stop and then the accelerstor to the floor takes a little practice to get it right
Old Jun 12, 2018 | 12:24 AM
Mobil 1's Avatar
Mobil 1
Of course it wants to move forward...that's why you must push brake as hard as you can. NORMAL
Old Jun 12, 2018 | 06:53 AM
Dcasole's Avatar
Dcasole
Have you put the car in Track mode and then pressed the button twice to turn off TC and stabiatrack off and put the car in Competitive mode your dash should display this if you are doing this right in the center of the speedometer. Then stand on the brake as hard as you can . Depress the gas pedal to the floor , the converter will flash to 2100, 2500 and then settle at 1800 , depend on temperature once it settles let your foot off the brake and hang on
Dave
To Launch control without PTM
