Creaking Noises
Old Jun 13, 2018 | 07:31 AM
Big Behr's Avatar
Big Behr
Default Creaking Noises
Anyone else have creaking noises from their roof? The latch above my head is constantly creaking and driving me crazy. Sometimes I drive with my side unlatched to stop the creaking.
Any fixes for this?
Old Jun 13, 2018 | 08:15 AM
Red C8 of Jax's Avatar
Red C8 of Jax
I had the same problem with my 2015 and took it to the dealer and they replaced the latches and pins and the creaking got much better. This seems to be a common problem with early C-7's.
Old Jun 13, 2018 | 09:01 AM
proeagles's Avatar
proeagles
There are a million posts on this. My new Stingray creaks as well despite everyone saying the problem was fixed after 2015. It's a plastic car, we'll have to get used to it. I don't believe anyone who says their car doesn't creak. I'm 0 for 2 and everyone I've been in creaks. I hope the C8 is an actual coupe and not some pretend to be coupe convertible. If I wanted the damn top off I'd buy a convertible.
Old Jun 13, 2018 | 09:24 AM
Jmhornz71's Avatar
Jmhornz71
Try some heat shrink on the pins it stopped the creaking on my C6 lasts several months then needs to be redone. My 15's top does a little creaking not enough to warrant any fixes
Old Jun 13, 2018 | 09:30 AM
ColoradoGS's Avatar
ColoradoGS
There are many different variations of the squeaking / creaking issues. Front targa latches, rear of the targa, and other places. If it helps I had the rear of the targa variation. Here was this fix:
It use to happen consistently at ~2500 rpms. I've heard no squeaking since the fix was applied.
Old Jun 13, 2018 | 12:14 PM
Cirrus8's Avatar
Cirrus8
My fix for this problem was to pull the top and lube the pins (front and back) with silicon dielectric grease and while I was at it, I also put a thin coat of grease on all of the rubber moldings and a thin coat on the locking surfaces of the cams. I stress THIN coating and application on a warm or hot day since the silicon does not cover easily when it is cold. I also added silicon into the pin holes. And while I was at it, I also did all of the rubber molding around the doors, hatch and hood. The result was a completely quiet car. No creaks, squeeks, or groans!! Good Luck.
Old Jun 13, 2018 | 03:17 PM
TXSteveF's Avatar
TXSteveF
Exactly what Cirrus8 said. I just went through this and when I was finished my top was quite. Easy and cheap fix.
To Creaking Noises
