Driving Mode
Old Feb 24, 2020 | 10:37 AM
  #101
j0evette's Avatar
j0evette
90% Sport and 10% Touring with NPP fuse pulled.
Old Feb 24, 2020 | 02:06 PM
  #102
arvindnc's Avatar
arvindnc
Default Driving Mode
Originally Posted by subsailor74
What mode do most C7 owners use for day to day driving? I leave mine in "T" or Touring Mode. I have used the Sport mode a few times and did not notice any difference in driving my Stingray. I do not intend to use the Track mode as I do not plan to drive my car on a track.
Leave it on any mode for the base Stingray. It wont make any difference on the street. You may notice a slight difference in the way it shifts gears (Automatic) if you drive it hard or on the track. The higher models will have a better noticeable change in the way the suspension reacts if equipped with magnetic suspension. For all practical purposes, drive mode on the base Stingray is a gimmick and completely useless and pointless.
Old Feb 24, 2020 | 03:08 PM
  #103
boss2k's Avatar
boss2k
Who says says so, I have a base stingray with MSRC and the suspension changes are very visible in touring vs sports vs track mode
Old Feb 24, 2020 | 03:14 PM
  #104
arvindnc's Avatar
arvindnc
Default MSRC on a base stingray?
The base stingray LT1 does not come standard with MSRC ( Magnetic controlled suspension?) If you had an option of having one you will see a difference in the way the suspension tightens up in sport or track mode. Mine does not have a magnetic suspension and neither it has the valves controlling the exhaust note, hence the drive mode is pretty much pointless other than the minor gear shift changes I see under hard acceleration or driving on the track.
Old Feb 24, 2020 | 04:06 PM
  #105
boss2k's Avatar
boss2k
ok got it
Old Feb 24, 2020 | 06:35 PM
  #106
itch808's Avatar
itch808
Street: Tour 100%
Autocross: Track + Race PTM
Old Feb 24, 2020 | 09:09 PM
  #107
Rapid Fred's Avatar
Rapid Fred
Tour in the winter; Sport the other three seasons. I will use Weather mode in the rain and have used Economy on long Interstate stretches...
Old Feb 25, 2020 | 10:21 AM
  #108
Woodson's Avatar
Woodson
You can’t feel the difference in steering?
Edit: and you bought an automatic and a base with no MSRC to track?
Old Feb 25, 2020 | 11:00 AM
  #109
arvindnc's Avatar
arvindnc
No! I bought the Stingray as my daily commuter. I do not see any difference in the steering under any driving mode under normal driving conditions. The only difference is the way the gears shift when you drive it hard on the highway or on a track. I do not track it regularly. I have only done it couple times just for the heck of it. Oh! Please don't tell me you are a NASCAR driver driver and you bought your corvette for racing. LOL
Old Feb 25, 2020 | 11:25 AM
  #110
Neil Baker's Avatar
Neil Baker
What is the difference between Sport exhaust and Track exhaust? Thought they were the same!
Old Feb 25, 2020 | 11:35 AM
  #111
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
They are slightly different. You'll mainly notice it when cruising at highway speeds where Track will be open, and Sport it closed. Personally I prefer Sport so I don't get the slight drone on the highway.
My settings for daily driving are (Z51 w/Mag Ride):
Suspension: Tour
Exhaust: Sport
Steering: Sport
If the wife is in the car or we're doing a trip, I'll typically switch the exhaust mode to Tour.
Old Feb 25, 2020 | 03:26 PM
  #112
vette2284's Avatar
vette2284
Steering sport. Fuse 42 pulled
I use sport most of time. Sometimes track. Tried w in heavy rain. I thought it made a difference. Does anyone think track steering slightly heavier
Old Feb 25, 2020 | 04:24 PM
  #113
guido7834's Avatar
guido7834
So on a base stingray without MSRC and non NPP, just what changes in each different driving mode? Throttle progression?
Old Feb 25, 2020 | 04:36 PM
  #114
arvindnc's Avatar
arvindnc
According to the dealer the only thing noticeable is the way it shifts the automatic gears , ie, long shifts in tour and eco mode vs short quick shifts in sport and track mode. Weather mode protects you against spinning out of control but useless if you are going at high speeds as it will not stop from hydroplaning or skidding on ice. Plus there is that different gauge that lights up your dashboard when you flip it to track mode. So on a base stingray LT1 without any extras it is mostly cosmetic improvements and minor gear shift patterns is all that is noticeable. Everything else is imaginary. It is very different in the well equipped models where you can change the way the suspension, exhaust note, transmission and the steering behaves. Base LT1 models do not have any of that as they are simply not equipped for those changes.
Old Feb 25, 2020 | 04:39 PM
  #115
juanvaldez's Avatar
juanvaldez
The steering feel in the base stingray is not imaginary.
Old Feb 25, 2020 | 05:11 PM
  #116
arvindnc's Avatar
arvindnc
I have to confess that I have not noticed any significant difference in the steering feel under track or sport mode. But then I was not paying close attention to it. I will check it out tomorrow, if weather permits, on a winding road to see if it makes a real difference in different modes. So far, it has not been dramatic enough to notice anything to talk about.
Old Feb 25, 2020 | 05:17 PM
  #117
EvanZR1's Avatar
EvanZR1
First off, it's 1LT, not LT1. LT1 is an engine, 1LT/2LT/3LT are trim levels. And even saying 1LT doesn't have those things is wrong as well, you could order Z51 & Mag Ride on a 1LT trim car.
Second, I wouldn't trust a dealer to give me any info. Here's the real info:
ALL C7s adjust traction control and steering feel based on the mode selector (unless you independently change steering through the infotainment screen, which was available on 2015 and newer).
If you have NPP, which could be ordered separately from anything else including Z51, 1/2/3LT, etc, then mode selector controls exhaust (again unless you independently change through the infotainment screen).
If you have MSRC (Mag Ride), which could be ordered separately from anything else including Z51, 1/2/3LT, etc (I believe starting in 2016), then mode selector controls suspension setting.
If you have Z51/Z06/ZR1 AND MSRC, then you also get PTM (Performance Traction Management), which is controlled through the mode selector (and TC button).
To Driving Mode
Old Feb 25, 2020 | 05:24 PM
  #118
EvanZR1's Avatar
EvanZR1
It's subtle, but there is a difference. It's most noticeable on slow/tight turns (thing parking lot). I'm not positive, but I have a feeling Tour mode steering stiffens up with speed and probably becomes close to sport at speed.
Old Feb 25, 2020 | 05:53 PM
  #119
arvindnc's Avatar
arvindnc
Default Drive Mode
Thanks for the correction. I meant Stingray 1LT which is the most basic model you can buy without any extras. There are no settings for any changes on infotainment screen. Traction control is a separate button which is either on or off. As I mentioned I am referring to "Normal" driving conditions at legal speeds. I have played around with every setting and it did not make a noticeable difference. It even flips to V4 in track mode (Go Figure) absolutely no difference in gas mileage. Then again we are talking about the base stingray 1LT with no extras.
Old Feb 25, 2020 | 06:30 PM
  #120
Woodson's Avatar
Woodson
Ok, we will wait for your confirmation of something we all already know.
