Did you know....
Old Aug 2, 2018 | 12:27 PM
Maxpowers's Avatar
Maxpowers
Default Did you know....
So I've been a car geek my entire life and spend at least 1 - 2 hours a day reading car articles or being on this forum.
I just learned today that every car has a little triangle next to the gas gauge icon. It points in the direction of the gas cap. Useful info for when driving a rental or some buddy's car. I can't believe I just discovered this today.
Old Aug 2, 2018 | 01:58 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Been out for a while on many cars. Hopefully you were at the gas station when you noticed this. You appear to be running close to empty.
Old Aug 2, 2018 | 02:08 PM
mschuyler's Avatar
mschuyler
Umm, it's close to FULL.
Old Aug 2, 2018 | 02:35 PM
Kevin A Jones's Avatar
Kevin A Jones
You are very honest in admitting you didn't know that.
Perhaps they should make it look less like a triangle and more like an arrow.
Old Aug 2, 2018 | 04:44 PM
dvilin's Avatar
dvilin
Been on cars of all makes/models for several years.
Old Aug 2, 2018 | 05:00 PM
redman76's Avatar
redman76
St. Jude Donor '09
To answer your question . . . yes.
Old Aug 2, 2018 | 05:27 PM
Tally Ho's Avatar
Tally Ho
DUH!!! That gauge gets me every time. I was looking at the needle and not the markers.Thanks for the correction. I've lost count of how many times I've had to double take a look at mine. All of my other cars indicate full on the right, empty on the left.
Old Aug 2, 2018 | 05:36 PM
Avanti's Avatar
Avanti
Didn't know (like a lot of the superfluous stuff) and don't care. But, thank you for the info.
Old Aug 2, 2018 | 06:09 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
RELATED SHAGGY DOG STORY:
Reminds me of my 1st car a '41 Ford coupe that I stuffed in a '50 Olds engine. No way that 6 volts system would start that big block (well it was a big block in the day as I had it bored 1/8 inches for '55 pistons! ) A company I town sold 6/12 and 12/24 volt batteries (mostly the 12/24 for trucks.) It was essentially two 6 volt batteries that had a solenoid on top that when starting put the batteries in series and you had 12 volts to turn the starter. Turns out 12 volts on a 6 volt starter works fine for a short crack! Therefore all lights and gauges operated on the 6 volt system in the car. The solenoid switched to put them in parallel for running and charging.
Now the reason for posting. The gas gauge read backward! Not sure why but was not going to take the dash apart to find out. AND thought it was a great antitheft device! Although working part time when in high school, which paid for the car etc, had little money for gas so was always running close to empty! But the gauge read almost full! If someone stole the car they would run out of gas!
Old Aug 2, 2018 | 06:11 PM
ImpliedConsent's Avatar
ImpliedConsent
You obviously care or you would not have posted. Yup, that arrow has been around for awhile. First time I noticed it was on my 2003 GMC Sierra.
Old Aug 2, 2018 | 06:14 PM
Maxpowers's Avatar
Maxpowers
Don't feel bad. The day I picked up my vette from the dealer, I thought I was close to empty based on the gauge being the opposite of most others . I kept pumping gas in with no luck. Turns out it was full LOL...
Old Aug 2, 2018 | 06:41 PM
fsvoboda's Avatar
fsvoboda
And now every driver in America knows this!
No, seriously, thanks for the reminder. I am sure a lot of people actually don't know.
Old Aug 2, 2018 | 06:42 PM
mic575's Avatar
mic575
I did know this but I was equally amazed when I learned it the first time. Which way does the arrow point on the C4?
Old Aug 3, 2018 | 12:46 AM
Maxie2U's Avatar
Maxie2U
Never knew that....thanks.
It’s like when I discovered on boxes of aluminum foil, saran wrap and wax paper have locking tabs on the sides to help hold the rolls in place! Duh.
Old Aug 3, 2018 | 07:44 AM
Corgidog1's Avatar
Corgidog1
That info is helpful when driving an unfamiliar car that you need to refill with gas.
oops just realized I live in NJ where attendants pump your gas and refuse if the gas tank in not on the same side as the gas pump.
Old Aug 3, 2018 | 11:35 AM
Parcival's Avatar
Parcival
srsly, maybe red-green color blind? Can you see the red coloring on the 0 side? Or just didn’t look?
Old Aug 3, 2018 | 11:43 AM
orca1946's Avatar
orca1946
And the gauge reads "ONE = 1 " when full not "F"
To Did you know....
Old Aug 3, 2018 | 12:32 PM
Rebel Yell's Avatar
Rebel Yell
Oddly I knew that, but I did not know you could put 212 psi in the tires.
Old Aug 3, 2018 | 12:55 PM
Null Pointer's Avatar
Null Pointer
Exception ID 10T
Just like the rocker on/off switch on some of my power equipment O/1 So does that O mean OFF, or ON? In my binary world during my IT career 0 was off, 1 was on.
WTF? That Corvette gas guage reading backwards from every other vehicle I have ever owned, including my C6, confused me the first time I looked at it. I forget when I
first figured out the triangle thingy and I recall having a "DUH" moment when I did figure it out.
Old Aug 3, 2018 | 01:06 PM
papillion's Avatar
papillion
Default Eureka
2-3 years ago, I read about the triangle on the gas gauge in an online 'what is that' article. Hmm? Mind you, I got my first car for my 16th birthday. JFK was President then. Went immediately to the garage and found it on the F150 and C7. Sent an email to my brother who had no clue either. But looked at his Jaguar and voila. So I've had a lot of cars in the last 55 years and until maybe 2014-15 had no idea. Hadn't noticed it. Other than curiosity still don't much care. Guess it might enlighten me with a rental car? An interesting factoid that is as interesting that it remains a new revelation for someone everyday.
