2015 LT1 backfire
Old Aug 22, 2018 | 11:52 AM
rsgood's Avatar
rsgood
6th Gear
Default 2015 LT1 backfire
When the auto shifts from first to second under max throttle there is a loud pop like a backfire which is also felt. this can't be normal. is this a known condition? is there a fix for this?
Old Aug 22, 2018 | 12:05 PM
stab1991's Avatar
stab1991
Normal
Old Aug 22, 2018 | 12:20 PM
BLKTOUT's Avatar
BLKTOUT
It is by design. If you push it hard enough you will have the same effect as it shifts into the higher gears as well.
Old Aug 22, 2018 | 01:30 PM
rsgood's Avatar
rsgood
6th Gear
Thanks for the response fellas, I'm new to the site and just found the answer in old posts.
To 2015 LT1 backfire
