AFM Range Tech Idea
PS: Why is that people think they can be dicks and then self-exonerate themselves with "Cheers" and a beer glass? A dick is a dick, emoticon or not. Own your actions.
don't pay attention to him and maybe he will go away lol lol
Dave
Dave
- AFM ON
- AFM OFF below 35 mph
- AFM OFF below 66 mph
- AFM OFF
(Or heck even simpler, a rocker switch that just had two positions, AFM OFF and AFM OFF BELOW 65).
So that gives you the option to selectively turn it off in the city but keeping it for the highway, which is how I coded mine up. That lets me drop down to V4 at 75mph and just cruise cheaply.
Thoughts? Would you want it selectable? It'd be trivial for them to do.
I have a slight shutter once in awhile when it's running in V4, and it varies from slight to non existent over the course of driving around 4-5 hours in a day.
Cruising anywhere from 65 mph on up can't, tell if it's in V8 or V4.
IMO GM should have programmed it as you suggest, Off at low speeds, On at highway speeds.
My Range is setup with an On/Off switch and I turn it on After the engine is started.
And there is no ill affect turning it Off and On while driving.
It's no different than the way it turns Off and On from the factory except now its controlled manually.
::cheers
But I don't want it kicking in around town now that I have the Corsa exhaust, it gurgles and drones (in AFM only). So I turned it off in the city, but kept it on the highway, and thought others might want that same flexibility, but it would seem not! Question asked and answered.
I do understand OP'S Thinking.
But to answer your question about 'why not shut a few cyl down' - because it causes massive drivetrain vibrations that damage the drivetrain. Look up the issues the A8 cars have had and look up how the GM designers talked about strengthening the driveline to deal with said vibrations. Sure, GM saves some money on emissions laws, but the customer ends up with drivetrain problems.
I just got back from a road trip to Michigan. With the Range installed (8cyl mode all the time) I averaged 26.9mpg with the AC on.
thanks for the input
Edit
i did find more to read on the topic here. It seems the AFM is the issue. I still ask, should I be worried?
Dave
Edit
But there is one thing I read out of all of them that makes me take notice.
With the A8 being a longer Transmission because of the 8 Gears, GM had to use a Short Stubby TC in order for it to fit in the C7.
In a word, apparently it's not Robust enough to handle the constant engaging and disengaging of the Clutch Packs while in V4.
The vast majority work fine, but there's definitely many that do not.
With the latest Transmission fluid formula used for the Flush fix, it helps some owners, but not others, then a new TC is put in.
There's been a lot of success with either one of those fix options, but, not 100% for either.
So in one sense we could say AFM is at fault, but it wouldn't be if the TC was able to handle it.
AFM actually works fine, it's the TC that doesn't because it can't handle it.
And yes, without AFM we wouldn't have this problem, or would we ?
There's been some owners that knew about this possible issue and never used AFM V4 mode since new and they still needed a new TC
My question is, with thousands of C7's with the A8 out there without TC problems, why does it happen to some, and not others.
Just my thoughts and info for what its worth
Roll off the Dice?
Or not?
::cheers
