Ground clearance
Old Sep 27, 2018 | 07:35 AM
jmanenforcer's Avatar
jmanenforcer
Cruising
Default Ground clearance
Does anyone know what ground clearance is on a stingray? Including the air dam?
Old Sep 27, 2018 | 05:31 PM
JMII's Avatar
JMII
The only number I can currently remember is that on my Z51 the jacking pucks are 5.5" off the ground. They are not the lowest part of the car but pretty close to it. Just looking at it I would guess that the flexible plastic flaps (air dam?) in front of the wheels under the front bumper would be the lowest part of the car.
Old Sep 27, 2018 | 06:00 PM
joemessman's Avatar
joemessman
On my Stingray it is 3" to the air dam and 6" to the metal.
Old Sep 27, 2018 | 08:50 PM
Avanti's Avatar
Avanti
3-1/4" on my '18 Stingray.
Old Sep 28, 2018 | 07:35 AM
jmanenforcer
Cruising
Thanks guys I appreciate it.
Old Sep 28, 2018 | 09:11 AM
MMD's Avatar
MMD
is this stock height or did you lower the front end any?
Old Sep 28, 2018 | 12:12 PM
BlueDevilZ51's Avatar
BlueDevilZ51
I took off the air dams so lowest point on my Z51 is 2 3/4" at the bottom of the splitter.
Old Sep 28, 2018 | 12:48 PM
joemessman's Avatar
joemessman
Just stock. My understanding is that these cars will vary here and there a little bit.
Old Sep 28, 2018 | 01:51 PM
MMD's Avatar
MMD
It must be possible to raise the front end some. Have you ever considered this? I just ordered a new 19 GS with stage 2 aero, I am concerned about damage to the front splitter. I had a mustang that had a spitter with 5" of ground clearance and I painfully know how easy it was to bottom out and the damage this causes. 3" is ridiculous.
Old Sep 28, 2018 | 01:57 PM
joemessman's Avatar
joemessman
I hear you, but I very seldom hit the air dam in my 77,600 miles. It looks brand new. I can forecast that if I had a splitter to be concerned about I probably would have been more careful. Every time I did touch it I knew there was a chance. If I had a splitter I wouldn't have attempted to continue on my path. I psychologically know I have that flexible air dam that is inexpensive and easy to replace. Mine is at the top of the bolts now for lowering, etc. So it is as high as it is going to get.
Old Sep 28, 2018 | 02:02 PM
MMD's Avatar
MMD
You are very fortunate Joe. I think if you lived in Northern States your experience with splitter damage would be different, You are very fortunate to have gone 77,000+ miles without a problem.
To Ground clearance
