Vitesse Throttle Controller mounting
Old Oct 5, 2018 | 12:32 PM
Sandyeggo Designs's Avatar
0Sandyeggo Designs
Former Vendor
Default Vitesse Throttle Controller mounting
If you have, or are thinking of getting the Vitesse Throttle Controller for your C7, we'd like to show you a great way to mount it:
The VTC has a rotating dial to set the amount of throttle response you want. From 0 (no change from OEM) to 9. This means you can set the throttle response you want depending on the situation, traffic, driving conditions, etc. For example, if the road is slippery you could dial it back to reduce throttle sensitivity. On dry city streets you might set it to 4 or 5 to make the car more responsive in traffic. And on the open road or on the track you can dial it up as you wish to get a truly thrilling response from the throttle! However you like it, the sensitivity is adjustable on demand. That's the key feature of the VTC: it's adjustable on the fly.
For convenience, you want the VTC to be mounted where it is readily accessible. You don't want to have to open the arm rest or reach down somewhere to get to the dial. Or take your eyes off the road to find it. It should be mounted right at your finger tips where it can be set easily.
We offer our VTC mount for only $12.99. It installs in minutes and can be removed at any time. You can get yours here: Sandyeggo Designs
Cheers,
Dave
Old Oct 5, 2018 | 01:54 PM
rsvette12's Avatar
rsvette12
Highly recommend this product - luv mine
