Fuel injector cleaner
Old Oct 15, 2018 | 03:48 PM
Foosh's Avatar
Foosh
Yes, a few people get struck by lightning too.
Old Oct 15, 2018 | 03:58 PM
dbaker's Avatar
dbaker
Yep.....I run a can of Techron (Black container) in my newer cars at every OCI.
For older cars with high mileage,I use BG44K once a year.
\db2
Old Oct 15, 2018 | 04:34 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Originally Posted by JJB82
I heard chevron with techron is the best fuel injector cleaner to use. I have also heard that it’s best to use it right before an oil change because some of the contaminants that the fuel injector cleaner gets rid of can end up in the oil pan. Is there any truth to this?
I use it as insurance to keep sulfur from fouling the fuel sender! If you look at the 3 or 4 published benefits for the GM additive and Techron they both list keeping the fuel sender from fouling as a benefit. It fact a number of posts where folks fixed a fouled sender using both products.
The issue with the C7 is to replace a fouled fuel sender requires dropping the rear drive train to get the tanks and cross over down! One poster said he was horrified when he say it all on the garage floor. Really don't want a dealer doing that and hoping they get it back properly!
Old Oct 15, 2018 | 07:22 PM
ahero4eternity's Avatar
ahero4eternity
It's cheap insurance for peace of mind if you ask me. Just chalk it up to the Corvette Tax. Rather spend a few bucks on Techron than deal with replacing the fuel sender, especially now that I'm out of warranty.
Old Oct 15, 2018 | 10:36 PM
JerryU's Avatar
JerryU
Originally Posted by MMD
GM Corvette has been recommending ACDelco 88865595 Fuel System Treatment - 12 oz since 2013 in their Corvette and other GM products since 2013 to help resolve the sulphur problem with the fuel sending unit. If you check you will find the recommended product chemistry is "not" relabeled Techron.
The ACDelco Product is manufactured by:
Excelda Manufacturing
12785 Emerson Dr.
Brighton, MI 48116
Techron is manufactured by:
Chevron Products Company
a division of Chevron U.S.A. Inc. 6001 Bollinger Canyon Rd.
San Ramon, CA 94583
These products appear to have different chemistries.
The 2014 C7 Owner's Manual says:
If TOP TIER Detergent Gasoline is not available, one bottle of Fuel System Treatment PLUS, part number 88861013, added to the fuel tank at every engine oil change, can help. Fuel System Treatment PLUS is the only gasoline additive recommended by General Motors. It is available at your dealer.
The 2017 Owner's Manual just says:
If TOP TIER Detergent Gasoline is not available, one bottle of GM Fuel System Treatment Cleaner added to the fuel tank at every engine oil change, can help. GM Fuel System Treatment Cleaner is the only gasoline additive recommended by General Motors. It is available at your dealer.
Old Oct 15, 2018 | 10:49 PM
PatternDayTrader's Avatar
PatternDayTrader
88861013 seems to be the exact same product as PN 88865595, except it actually says the 88865595 number on the bottle, and not 88861013.
Old Oct 15, 2018 | 11:46 PM
gilbybarr's Avatar
gilbybarr
Techron is the best in my experience. But, I use Costco gas which is a Top Tier fuel that comes WITH the chemicals to clean injectors. If you don't use a Top Tier rated fuel, I'd dose it with Techron twice a year before an oil change.
Old Oct 16, 2018 | 12:02 AM
Matthewstorm's Avatar
Matthewstorm
Can I add Techron to Flexfuel (E85)?
Old Oct 16, 2018 | 05:57 AM
JerryU's Avatar
JerryU
I use to use Techron until I viewed all the YouTube videos that show it to be ineffective. Save your $$$. I would recommend you use something like Stabil in your gas tank this winter if your car will be garaged most of the winter. Ethanol is a killer for gunking up fuel systems.
Yep, have watched some of those videos! They are attempting to show how effective Techron is in "removing" carbon deposits from the combustion chamber! Once the "stuff" is baked on not easy to get off! IMO, it was a limited narrow goal test based on what they could measure using a fiber optic camera!
Techron is Chevron’s patented cleaning additive and is what at least started the Top Tier gas when BMW and others said a gasoline clealing additive was needed to stop intake valve "coking" when cars used port injection, but that’s another story! Several gas companies paid Chevron a royalty to use it and now many have developed their own, “gas cleaners.” The "stuff" works. In fact, one of those detailed YouTube Video tests showed it was somewhat effective in cleaning baked on deposits on some cylinders. That was all they could "see" with their fiber optic camera. They could NOT check to see is it was doing anything in the injectors, for exapmle. A small amount of deposit in the very narrow injector passages can have a significant effect on performance.
Adding a container of Techron does help remove sulfur depositis from the fuel senders and is probably a help with injector deposits. By the way, cleaning additives are required in all gasoline, just not at the level needed to meet Top Tier.
I posted the pic below from when gas companies were advertising their Cleaning Additive Package to prevent "intake valve coking." Note it can do NOTHING for the backs of DI engine intake valves as there is NO gas passing over the hot intake valves to clean off baked on PVC “stuff.”
Only posting so others don’t read what I consider those video's and your incorrect conclusion as a reason NOT to use a gasoline additive like Techron!
Old Oct 16, 2018 | 11:44 AM
MMD's Avatar
MMD
The topic of burning fuels and combustion by-products in the automobile is an amazingly complex topic. Even automobile industry experts cannot agree as to what works best at improving fuel efficiency, reducing exhaust emissions, and what is needed to keep engine fuel systems from clogging and keeping engines operating at peak efficiency. Throw in the ever changing requirements the EPA imposes over automakers and gasoline providers, the continuing pressure from the farm industry lobby at influencing legislators to allow higher levels of ethanol, and the variability in the base crude oil products themselves would appear to make the problem of keeping an an automotive internal engine and fuel system clean intractable. Using cartoons to make one's point does nothing to address this complexity. If you have a sincere interest in this topic I would suggest you run over to Wikipedia and read more about the topic "Top Tier Detergent Gasoline". Having read this article you will walk away with 2 primary conclusions - 1) their are no "magic" bullets in meeting all the demands we as people have for automotive fuels and, 2) the best consumers can do to insure their automobiles operate at peak efficiency and promotes engine life is to only use certified Top Tier fuels. Reading through the article you will gain a sense of just how inexact this entire field of science and technology really is. Discussion from experts believe many gasoline additives offer little to no benefits. General Motors fuels engineer Andrew Buczynsky says the various engine-cleaning additives available at auto-parts stores should be used with caution. He said some work but most don't, and that care must be taken when using these additives because some may contaminate the catalytic converter. What should the average consumer do? Most automotive experts recommend the continual use of certified Top Tier fuels. Is this recommendation any guarantee your vehicle's engine will perform and remain as clean as it did when brand new? Probably not, but what this industry seems to suggest is this is the best information they have available at this point in time. What else would you expect them to say? It is apparent this industry is in a constant state of flux. My own experiences with fuel additives, mostly with the product Techron was it offered very little benefit even with long term use. This was confirmed with an engine tear down and rebuild after 6 years of using this product. However YMMV.
Old Oct 16, 2018 | 11:57 AM
PatternDayTrader
Setting aside the Sulphur/fuel sender issues. Injector cleaner is only useful if you have dirty injectors, and if your car is running right, and there's no check engine light, then its pretty unlikely you have a dirty injector problem.
Old Oct 16, 2018 | 12:14 PM
orca1946's Avatar
orca1946
It can only help not hurt, so I continue to use it.
Old Oct 16, 2018 | 12:19 PM
  #33
Patman's Avatar
Patman
Just two posts up from yours there is mention that it could harm the catalytic converters though, so I still say the safest plan of action when you buy a new C7 is to start using nothing but Top Tier gas and never add anything else to the tank.
Old Oct 16, 2018 | 12:38 PM
  #34
ElGreco53's Avatar
ElGreco53
Here's a handy link, FWIW: https://www.toptiergas.com/licensed-brands/
Old Oct 16, 2018 | 12:51 PM
  #35
drewz06's Avatar
drewz06
thing knower
it doesn't matter where you fill, just find the newest station, or at least the ones with the newest tanks...
don't go to old stations, think about the crap on the bottom of ten year old station tanks
Old Oct 16, 2018 | 12:55 PM
  #36
JerryU's Avatar
JerryU
The topic of burning fuels and combustion by-products in the automobile is an amazingly complex topic. ....General Motors fuels engineer Andrew Buczynsky says the various engine-cleaning additives available at auto-parts stores should be used with caution. He said some work but most don't, and that care must be taken when using these additives because some may contaminate the catalytic converter. .... My own experiences with fuel additives, mostly with the product Techron was it offered very little benefit even with long term use. This was confirmed with an engine tear down and rebuild after 6 years of using this product. However YMMV.
Agree it’s complex but you quote the GM fuel engineer saying, “some work!” IMO that includes Chevron’s patented Techron and the “stuff” GM sells. Which from the SDS sheet sure looks very similar! I use it to help prevent sulfur contamination of the fuel sender and several folks have used Techron to solve a fuel sender problem they encountered even though they always use Techron!
Two days ago OWC6 in a Post on the subject, stated:
“Mine took 8 or 10 bottles (Techron) before it seems to be finally fixed.
It's always had top tier fuel since new, but still had a problem at about 95,000 miles. I wasn't going to plow a bunch of money into it if I could help it. I just set the trip odo when filling up and kept track of miles and mpg.
The range function on the DIC didn't work when it was misbehaving, but the on Star app still had the range accurately, somehow.
It took 5000 miles, but (knock-wood) , it seems to actually be fixed, now.”
Suggest quoting Wikipedia is NOT the best source. Heck I contribute to it in my area of expertise-welding! I get two SAE publications each month and will buy an SAE tech paper when I see one of interest! I have run an engine on a dyno in undergraduate classes (recall covering the overheat light with book so the Prof didn't see it as I was leading a Lab team and we needed more time to get volumetric efficiency and some of the many parameters we had to measure! )
Recently attended a combined SAE/ASME joint Section meeting (I Chair our local ASME Section) in Rock Hill SC where we toured the USA Porsche Racing team facility. My opinion is based on some facts. My technical expertise is welding and was the 2007 President (a volunteer position) of that 70,000-member organization (actually <5% welders as members are mostly professionals.)
From forum posts I am convinced a steady diet of Top Tier is best but it does not hurt to add a bottle of GM (and I believe Techron) cleaner to help the fuel sender issue if nothing else.
Old Oct 16, 2018 | 05:18 PM
  #37
Skid Row Joe's Avatar
Skid Row Joe
If GM advises additive use, then it's excellent advise regards fuel system cleansing. 👍
To Fuel injector cleaner
Old Oct 16, 2018 | 07:52 PM
  #38
Patman's Avatar
Patman
So you agree with GM when it comes to the fuel system but you completely ignore their recommendations when it comes to oil changes and the proper octane of gas to run?
Old Oct 16, 2018 | 08:45 PM
  #39
PatternDayTrader
Lol ...
Old Oct 17, 2018 | 12:15 AM
  #40
owc6's Avatar
owc6
I thought I'd clarify to what Jerry quoted (which is accurate from what I related in another thread, btw):
Mine didn't fail until 95,000 miles, and when it did, it failed in the first half of the tank level at about 50-80 miles after fill up. Then about 40-100 miles later, a CEL came on. (P2066) The fuel gauge generally (usually, but not always) started working at about a quarter tank. Sometimes, the CEL cleared , sometimes not. This repeated even after several doses of Techron. Fairly repeatable.
After many doses( I honestly lost track of count), it started behaving more normally, and it has been behaving for about a thousand miles, except for one random CEL (no code known and the gauge was behaving at the time) for about 50 miles.
My guess is that a portion of the unit (which senses the top half of the tank level) was contaminated (sulphur) after all the miles despite having only Top-tier gas (Shell predominantly ).
I plan on throwing another bottle or two of Techron at it in the immediate future, and one every so often.
