Fuel injector cleaner
I heard chevron with techron is the best fuel injector cleaner to use. I have also heard that it’s best to use it right before an oil change because some of the contaminants that the fuel injector cleaner gets rid of can end up in the oil pan. Is there any truth to this?
Popular Reply
10-14-2018, 01:24 PM
Techron usage used to be recommended by many manufacturers such as BMW before the advent of the TopTier™ fuel standard. Before that, many manufacturers had injector clog issues, and that's what led a consortium of manufacturers including BMW, GM, VW and others to develop the standard.
Exclusive use of a TopTier™ certified fuel eliminates the need to do that. Techron is similar to the additives specified by the TopTier™ standard. As a matter of fact, GM still recommends in the owner's manual the use of GM-branded additive periodically if not using TopTier™ fuel.
I use to use Techron until I viewed all the YouTube videos that show it to be ineffective. Save your $$$. I would recommend you use something like Stabil in your gas tank this winter if your car will be garaged most of the winter. Ethanol is a killer for gunking up fuel systems.
The following 6 users liked this post by Foosh:
DALE#3 (11-10-2018),
jimmie jam (10-15-2018),
orca1946 (10-16-2018),
Perf n Restore (10-15-2018),
Quick99 (11-15-2018),
and 1 others liked this post.
Foosh nailed it. Check it out: https://www.toptiergas.com/
Maxie2U (10-15-2018)
Regardless of the use of "Top Tier" fuels, the "additive" doesn't always make it into the product during the tanker upload process at the terminal. Some additive products aren't mixed with the fuel until it delivered to the fueling station. So while you may be fueling with "Top Tier" products, it varies when...and sometimes if...the additive makes it into the fuel. So, the use if an additive like Techron is a good idea.
I became sold on Techron after the replacement of a fuel tank level/pump assembly years ago in my last truck. The problem was that the level sending unit was fouled, sending erroneous readings to the gauge. The assembly was replaced under warranty. Talking to the dealer shop foreman, he educated me on the use of Top Tier fuel and the periodic use of Techron (as recommended by the manufacturer) to keep the variable resistor of the fuel level sending unit clean. At the time, Top Tier fuel wasn't as widely available as it is now. So, whenever I notice the fuel gauge is off, I add a bottle of Techron, and at the next fill up it reads normally again. I use Costco fuel almost exclusively in my current truck, more often than not in the C7. Even with Costco being a Top Tier provider, adding a bottle of Techron at about every fifth fill up has been the norm for all of my vehicles since.
Ironically, I noticed the other day after filling up my truck (at Costco), that the gauge was off a little. I guess that it's been a few too many fill ups since the last time added a bottle of Techron.
rogergcam (11-12-2018)
I had a problem with the fuel gauge in my 96. It stayed on full . After 2 fill ups with techron added the gauge went back to working perfectly. I would add some every so often and never had a problem I have used it in the 15 a few times whether iot has helped or not I dont know
Received 1,762 Likes
I guess that you don't believe in your own philosophy:
https://www.corvetteforum.com/forums...post1598141914
I'll stand by verifiable information provided by the vehicle manufacturer, the experience of a management technician at a well respected dealership that's been in business for over a century, plus my personal observations and experiences...over your opinion substantiated by a few "youtube" videos.
bjones7131 (11-11-2018)
Techron every 3rd fill up, and Techron fuel "System" cleaner every 5-6 fill ups. I was sold when I was a mileage counter
in another car and it increased my mileage 10-14% after a few bottles.
My brother owns and operates a fuel tanker business, which delivers to both TopTier and non-TopTier stations. The additives are mixed at time of loading, and the loading process includes a checklist which verifies the proper additive package for each customer is added at time of loading if it's being delivered to a TopTier retailer. The consequences for mis-delivery are very costly for the carrier, and it would be as bad as delivering 89 octane to premium tanks or diesel to gasoline tanks. It is tested.
Additive is injected into the fuel as it is loaded into the tanker for delivery. It is VERY precisely metered to ENSURE that ALL fuel is dosed. Yes, the State department of weights and measures inspects and calibrates the injector rates
Gasoline is a fungible commodity. Meaning that the gas you buy at Exxon, may in fact be loaded at almost ANY branded terminal. It will have additive that meets or exceeds the requirements the customer requires.
The only segregated product that I was aware of, (in Maryland) was the 94 octane Sunoco premium...We has segregated storage and delivery rack for that product. We loaded trucks for EVERY brand gas station in Md, WVa, northern Va, south central Pa, and even Delaware... (Exxon/Mobil, Sheetz, Costco, Amoco, Jiffy Mart...)
Gas is gas... (for the most part at large retail stations.)
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
^^^ Re the above by rrsperry. I recall when Top Tier gas first came into being. Unless I'm wrong, some of the first gas retailers to join were relatively unknown chains in the NE US. One of them was QuikTrip. Also, I think Sunoco was very late to join (maybe because of the number of octane-rated grades they sell, and the requirement that Top Tier gas has to be for all levels/grades sold, not just one or two) as was the successor company to Amoco in the US, BP..
daygojunior (05-13-2022)
Is this the Techron that people are using?
https://smile.amazon.com/Chevron-928...5%3A2470955011
Or this?
https://smile.amazon.com/Chevron-677...=techron&psc=1
Or this?
St. Jude Donor '10-'11-'12-'13-'14
Or this?
Or this?
ahero4eternity (10-15-2018)
GM Corvette has been recommending ACDelco 88865595 Fuel System Treatment - 12 oz since 2013 in their Corvette and other GM products since 2013 to help resolve the sulphur problem with the fuel sending unit. If you check you will find the recommended product chemistry is "not" relabeled Techron.
The ACDelco Product is manufactured by:
Excelda Manufacturing
12785 Emerson Dr.
Brighton, MI 48116
Techron is manufactured by:
Chevron Products Company
a division of Chevron U.S.A. Inc. 6001 Bollinger Canyon Rd.
San Ramon, CA 94583
These products appear to have different chemistries.
12785 Emerson Dr.
Brighton, MI 48116
San Ramon, CA 94583
As it happens, albeit rarely, with aviation fuel products, it does occasionally happen with automotive fuel products. Mistakes still happen.
