Quick Jack 5000
Old Nov 6, 2018 | 12:51 PM
Tinkertech's Avatar
Tinkertech
Default Quick Jack 5000
What combination of pucks and blocks do you use to lift your C7 for those who have a quick Jack 5000?
Old Nov 6, 2018 | 12:58 PM
GoatHead's Avatar
GoatHead
I use AC Composite jacking pucks and the large rubber blocks included with QuickJack
Old Nov 6, 2018 | 02:04 PM
MacRoadie's Avatar
MacRoadie
Following this one as my 5000 will be delivered this week.
Old Nov 6, 2018 | 02:10 PM
George_L's Avatar
George_L
I use removable jacking pucks from Wildvettes and the smaller blocks supplied by Quickjack. I have lowered the car on the stock bolts and I have installed CF side skirts and the combination clears them easily.
Old Nov 6, 2018 | 02:13 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
I use the jack pucks that you can get from just about any vendor here on the forum and the smaller of the blocks that come with the quick jack. The stability is just fine. I've had my quick jack since September and have used it probably 10 times already. I've had my C6 and C7 Z06 on it and my friend's BMW i8 and his BMW M6 convertible as well. Very versatile tool.
Old Nov 6, 2018 | 02:14 PM
MacRoadie's Avatar
MacRoadie
Good to hear. My Z06 is lowered on stock bolts, with the full 3LZ/Z07 packages and I was concerned about clearance.
Old Nov 6, 2018 | 02:25 PM
HooosierDaddy's Avatar
HooosierDaddy
Old hockey pucks here, there cheap (if not free) at most local rinks.
evoroadster's Avatar
evoroadster
Ditto.
Old Nov 6, 2018 | 02:46 PM
Apocolips's Avatar
Apocolips
Hockey pucks work as good or better than all of those special order units. You can get them on line from any online store or get some used ones from E**y. If you live up north you can probably get them at any sporting goods store.
Old Nov 7, 2018 | 05:45 PM
iclick's Avatar
iclick
Stay-in pucks and the small blocks supplied with the QuickJack. Haven't had any problems, but I make sure they're aligned well before jacking.
Old Nov 8, 2018 | 09:52 PM
franknbeans's Avatar
franknbeans
same here.
Old Nov 8, 2018 | 11:13 PM
JMII's Avatar
JMII
...but I make sure they're aligned well before jacking.
Watching videos of the Quick Jack in action it appears to pivot forward slightly as it comes up. How do you account for that in order to ensure it’s properly aligned onto the small pucks?
Old Nov 9, 2018 | 08:26 AM
George_L's Avatar
George_L
I make sure to have plenty of room between the the wall or the garage door (you can use the Quickjack in either direction). The car will move 12" to 18". I place the rails under the car and line up the rubber blocks so they are close. Then I raise the rails until they are about to touch and realign the rubber blocks before actually making contact. I then raise the lifts until the body raises an inch or so and recheck everything before lifting the rest of the way. If you lower the rails all the way at any time make sure to go through the checks again prior to lifting as a puck may fall out or the rails could shift. I lowered the lift to put oil in one time and didn't recheck the alignment before starting to lift the car again. I almost damaged a side skirt because the puck had shifted. Now I never take all the weight off the rails until I am done. I lower the car until the tires just touch if I plan to raise it again.
Old Nov 9, 2018 | 08:54 AM
JMII's Avatar
JMII
That's pretty significant... thanks for the warning.
Old Nov 9, 2018 | 05:00 PM
iclick's Avatar
iclick
I just raise the jack to a point just before touching the pucks and align the small QuickJack blocks before raising the car. Haven't had a problem doing it that way and haven't noticed a shift after the fact.
Old Nov 9, 2018 | 05:23 PM
HooosierDaddy
Receive my QuickJack from Costco today. Boxes were beat to **** but Chinese corrugated materials are **** to begin with, and I'm sure UPS was very gentle with them
  • No instructions as I'm sure they came out of the box that was missing 1 sq ft of it's side (thanks UPS), but the video was all that was needed
  • Setup is very easy, basically didn't need the instructions. It's not like you can put the fittings in the wrong spot.
  • Mine came with the new updated pump that has a self venting fill plug on the tank. (this was not covered in the video so threw me off a bit)
  • Tank took 2 quarts to get things running and then a small top off after running it up and down a few times. So the 2.1qts is probably spot on.
  • I had to take the Schrader valves out and rewrap the teflon tape. Apparently on the other side of the world they wrap teflon tape the opposite direction.
I'm not a small guy and yet there was plenty of room. Purchased so I could put a borla x pipe on (not a fan of jack stands). However; I think the cost of the lift made this a very expensive X-Pipe... But the it'll get plenty of use with other tasks, or at least that's how I justified it in my mind. X-Pipe sounds amazing BTW!
Old Dec 5, 2018 | 12:24 PM
PCMusicGuy's Avatar
PCMusicGuy
Mine arrives in similar condition, only I had broken/damaged wheels and hardware on the end and a leaking main cylinder. Got most of my issues solved but took weeks.
To Quick Jack 5000
Old Dec 5, 2018 | 12:52 PM
2008 Corvette's Avatar
2008 Corvette
This is a must for any new and old QuickJack users. Alignment of pucks to jack before the final lift. VERY IMPORTANT.
Old Dec 5, 2018 | 05:27 PM
TNSQUIRE's Avatar
TNSQUIRE
For anyone considering this purchase, Costco has a great sale right now.
Old Dec 5, 2018 | 08:43 PM
Z51 John's Avatar
Z51 John
Same here.
