If you have auto lock configured for your car, when you exit your car with the driver door open (works with passenger door open as well), press the unlock button for 3-4 seconds until you hear 3 chimes. Now the car doors and gas door will remain unlocked until your next ignition cycle. Handy if you have a passenger in car that wants to get out while you are filling up the car because as the alarm is disabled as well. I use this feature when washing and cleaning car too.
why don't you just turn off passive locks permanently? They seem to me to be more trouble than they are worth.
I used passive locks for the first 18 months of owning my car. I liked just walking away and not having to deal with the fob. I quit using the feature after finding it inconvenient as every time I wanted to play with the car in my garage I had to get the key.
I also found myself walking away from my other cars not locking them due to the habit I built with the C7.
Remember back when we used to have to insert a solid metal key into a tumbler?
This is just an option for people using passive locking. I get in and out the the car more often than I get gas or wash the car. FOB is always in my pocket.
I don't want to get my FOB out 2 to 3 times a day to lock/unlock it.
I am old school. I never want to become so dependent on any automated, semi-intelligent, technologies that I take it for granted. If the corvette had a manual key I wouldn't hesitate to use it as the default mode of entry. As this is absent I'll rely on using the FOB clicker to gain access. I guess I could leave the windows open and climb in.....nah...to old to do this.
Disarming the autolock also avoids setting the interior motion alarm that will sound off if the passenger moves their hand.
As for allowing the passenger to exit, that’s a real safety issue. Jet fuel is basically kerosene and much safer than gasoline, but we were required to have the jetway at the door if fueling with passengers on board.
^^THAT! That's exactly what I found myself doing with my other car. I thought it was a cool feature, but only a couple of times with the "other" car, had to turn off the feature and relearn how to hit the FOBs lock button.
Reason: OT: Why are we capitalizing FOB? I know why I do, but anyone else?
Conversely, the C7's fuel locking pin malfunctions in the locked position.
This is the worrying part - when it fails the default condition is locked. What I can't figure out is why does it click so many times? It seems to cycle at least twice when you exit the car. Maybe its detecting that the FOB is within range and unlocking the door?
Similar situation here but I turned it off after only two weeks. The car kept locking itself when I was cleaning it... and I just knew this was going to lead to problems like locking the FOB in the car or forgetting where the key was, etc. Personally I like pushing the button on the FOB and getting the confirmation from the lights and horn that the car is now secure. I believe if you leave a door open when attempting to arm the system it honks 3 times.
Do people really steal gas or mess with your fuel? This whole locking fuel door deal seems like the answer to a problem nobody has. Especially with the capless system on the C7 where you need a funnel just to get to the tank.
This is why many of us disabled it. I personally don't need it. I've read a couple stories of people who had it fail with the door closed/locked. That's all I needed to make my decision. It was a real pain for them to deal with.
If you have and use a battery maintainer and pop the trunk lid before the car passively locks it will remain unlocked as long as the trunk lid is ajar. I always plug in my battery maintainer, then just walk away with the lid unlatched. After about 20 min. the car's electrical system will go into sleep mode and the car will remain unlocked. Thus, there is no meaningful battery drain. This, of course, is a practical solution only in a secured location like a locked garage.
FYI, you don't need to click the fob to lock the car. I don't use auto lock. It's a PIA for me more times than not. I used to dig the fob out of my pocket to lock the car each time, then I realized that's an exercise in frustrations. As you're getting out, or just before while you're still sitting and the door is open, reach over and press the lock button on the door. Get out and walk away, fob untouched in pocket.
Some of you must have assumed the door was locked when it wasn't. You might want to check once or twice to make sure your favorite method is actually working. Lock the car as usual, walk away some 10 feet or so, remove your fob from you pocket and leave it safely away from the car. Walk back to the car and check your locks. Once your method is proven you'll have more confidence in knowing your car is in fact locked.
I like auto lock so I use it and there is no way I'm putting a bolt in my brand new car to disable the locking fuel cap. These forums are great but just like every other forum I visit there are way too many threads about doing this or that to our brand new cars because of some known problem that happened to a guy four years ago. It's great to share info but man some of this stuff just gets ridiculous.
These cars can be set up the way you like it whether it's auto locking or auto locking with a horn beep (the way I like it) and so many other options. Just because we may like it one way or another doesn't mean everybody should do it that way or else they are wrong. If you want to disable the locking fuel cap then go for it and if you don't like auto lock then don't use it. There is no right or wrong answer and I'm just going to set mine up the way I like and leave my fuel cap alone.
GM should offer buyers options, when they factory order a new car, that can be purchased to remove unwanted equipment and "features" such as the fuel door lock mechanism. Didn't Camaro some years ago offer an option on their ZL1 to remove features such as radio, air-conditioning, back seat to eliminate weight?
there is no way I'm putting a bolt in my brand new car to disable the locking fuel cap. These forums are great but just like every other forum I visit there are way too many threads about doing this or that to our brand new cars because of some known problem that happened to a guy four years ago. .
I would typically agree with you but this problem has occurred more than you think. If you're on a road trip and it happens, the only option other than a dealer visit is removing the wheel well liner (assuming you brought tools with you).
The beauty of the plastic scrivet is that it takes 3 seconds to do, no tools necessary, is 100% reversible in 3 seconds with no tools necessary. Cheap insurance, IMO.
OK this might be worth doing if you are going on a road trip or something where you will be with your car all the time and you don't want to worry about things.
I know many say why would anybody mess with your fuel tank? Well let me tell you there are a lot of crazies out there and they think they are normal. I'm an avid snowmobiler and there are some enviro nuts out there and there have been instances where they have put crap in fuel tanks of parked trucks that have snowmobile trailers hooked to them. They have also been known to slash tires on snowmobile trailers. Now these same enviro nuts might think we are abusive to the environmental well being with our sports cars and want to do the same thing. Having a locking fuel cap might be just enough to keep these zealots away from doing any harm. Then there are those who are jealous and feel we have too much.
This is why I am a proponent of the 2nd amendment. The crazies. A 10mm will get the job done better than a skrivet.
See post #34. The door can easily be popped off, without damage, using just a screwdriver and a couple of credit cards.
