Main info screen
Old Jan 2, 2019 | 10:48 AM
D MacLeod's Avatar
D MacLeod
4th Gear
Default Main info screen
My main screen is flashing alot and of course my warranty just ran out, Does this mean the screen is going and has anyone else had this happen
Old Jan 2, 2019 | 05:26 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Do you mean the gauges screen or the infotainment screen?
Old Jan 2, 2019 | 06:16 PM
D MacLeod's Avatar
D MacLeod
4th Gear
The Infotainment screen, keeps flickering
Old Jan 2, 2019 | 06:31 PM
2019GSTX's Avatar
2019GSTX
Lurker
St. Jude Donor '19-'20
Do a search on screen flickering. Someone recently posted on fixing the wires that plug into the screen. With the up/down movement they tend to eventually become intermittant, the wires get stressed.
Good luck!
Old Jan 2, 2019 | 06:45 PM
D MacLeod's Avatar
D MacLeod
4th Gear
Thanks for the insight, I'll check them
Old Jan 2, 2019 | 07:30 PM
bimmerborn's Avatar
bimmerborn
I had the same issue. When it happened the car was under warranty. So naturally I took it to dealer and they changed the screen. However as 2K14C7 mentioned, a recent thread pointed to a relatively easy fix.
Old Jan 2, 2019 | 08:12 PM
Frosty's Avatar
Frosty
I have generated a few threads on this. Every once in awhile my screen will flicker and I have to take off the little triangle on the driver side front part of the center console. Move the screen up and down until you can see the two blue wires. Give them a pull and they will reseat and all will be good for a long time. Beats having your dash ripped out
Old Jan 2, 2019 | 11:14 PM
D MacLeod's Avatar
D MacLeod
4th Gear
I will try that, sounds easy enough, thank you
Old Jan 3, 2019 | 02:40 PM
LarryFL's Avatar
LarryFL
Good luck!
What he said..
https://www.corvetteforum.com/forums...cheap-fix.html
To Main info screen
