Reset code
Old Jan 8, 2019 | 04:14 PM
bbrown450's Avatar
bbrown450
Default Reset code
swapped out air filter and did not seat the MAFS accurately enough realized right away ....too late and obviously have the CIL ( Trans) light lit.....seems to me I read on here that eventually it sorts itself out ... how long does that take as it prevents you from starting the car remotely....or do I need to get a code reader ... if so what is everybody reccomending.?
Thanks in advance
Old Jan 8, 2019 | 04:22 PM
Mobil 1's Avatar
Mobil 1
What do you mean TRANS? And CIL?
Old Jan 8, 2019 | 04:23 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Maybe his car self-identifies as a boat?
Old Jan 8, 2019 | 04:26 PM
bbrown450's Avatar
bbrown450
Looks like a transmission symbol..might be an engine ... but definately the one light that tells you something is amiss...did some reading ...might reset after a few start ups.... can potentially undo the negative terminal and wait 30 secs... or get an OBD2 tool ...would not mind having one if someone has a reccomendation ...thanks
Old Jan 8, 2019 | 04:29 PM
Maxpowers's Avatar
Maxpowers
Bluetooth OBD II readers are cheap and easy to use. I'd get one of those.
Old Jan 8, 2019 | 04:57 PM
bbrown450's Avatar
bbrown450
Thanks will do ....boat? ...there is one in every crowd...
Old Jan 8, 2019 | 05:06 PM
Mobil 1's Avatar
Mobil 1
You must mean CEL not CIL (Check Engine Light). Not sure about a trans light so I will assume its a engine. Just but a cheap OBDII reader/clearer at Walmart.
Old Jan 8, 2019 | 06:10 PM
Corvettes@FHDaileyChevrolet's Avatar
0Corvettes@FHDaileyChevrolet
Former Vendor
Thanks in advance
I had this happen on an air intake swap. Simple fix. Just disconnect the negative battery cable for 15 minutes and reconnect it. Then drive the car. It'll go away unless you didn't connect the sensor correctly.
Old Jan 8, 2019 | 08:36 PM
Mayor111's Avatar
Mayor111
Any local AutoZone store can do a CEL / code check for you...no need to buy a reader since they do it for free.
Old Jan 8, 2019 | 08:41 PM
eseibel67's Avatar
eseibel67
Light will probably go away by itself after a certain number of ignition cycles if all is reading properly.
Old Jan 9, 2019 | 12:52 PM
bbrown450's Avatar
bbrown450
Indeed it did ...thanks
Old Jan 10, 2019 | 01:18 PM
JoisyDevil's Avatar
JoisyDevil
My local auto zone (NJ) will not clear the codes. Allegedly they can be fined for trying to help people pass inspection.
To Reset code
