At 46k miles this went off with my check engine light and it was only on for 4 days then turned off. Now at 51k miles its on again. I do drive my car a **** ton and do not beat on it.
Does anyone believe this to be a faulty signal?
Is it a serious problem?
Is there a recall (I know there was some sort of faulty capless gas signal recall we had in the past)?
Can someone point me to the location of this O2 sensor?
I cant find one on the internet so far. Should I change the O2 sensor or is there another fix?
I cant get to changing it till the weekend, if it has to be changed. Thank you!
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
If the CEL comes on and then clears (and since you have a scanner apparently), check the history. That the light went back off means the condition was clear for x number of engine start/stop cycles. But as it threw the same code a few K miles later, I would at least check the sensor (and/or connection to it)
I would like to check it. But I do not know where it is located. I know in general where the sensors are located but I do not know which one bank 1 sensor 1 is.
Also I bought a fuel injection cleaner (techron) - waiting for the tank to go near empty. I haven't put any additives in the engine ever.
Bank 1 is drivers side, sensor 1 is before the cat.
That code you gave (P015BO2) doesn’t sound right. You sure you typed it in correctly?
Your check engine light problem should be covered under your powertrain warranty. You are under 5 years and 60,000 miles.
Take to your dealer to get fixed.
