A8 Flush
Old Jan 22, 2019 | 09:00 AM
Sixgun95's Avatar
Sixgun95
Default A8 Flush
Had the car in yesterday and the tech offered the triple flush, had zero problems, but said sure why not, warranty was paying for it. Says prep per bulletin #18-NA-355, triple flush and fill with DT-45096. This the most recent update for the famed shudder?
Old Jan 22, 2019 | 09:53 AM
bjones7131's Avatar
bjones7131
Really and U weren't having problems, Good for U and U must have a great dealer.
Old Jan 22, 2019 | 10:01 AM
LarryFL's Avatar
LarryFL
Yeah, why would they offer to fix what isn't broken? So far, haven't all A8 TSB's been 'perform only if customer complains' ?
Old Jan 22, 2019 | 10:16 AM
kensredvette2's Avatar
kensredvette2
^^ Definitely a great dealer.
Shudder, according now to GM info is related to the ATF picking up moisture from the air, thus changing the friction properties. GM is mum about whether the moisture has changed/damaged the friction material in the tranny. The fluid retains the moisture even if the fluid gets warm so the moisture stays in the fluid. GM info has highest priority for new fluid changes in the southeast and south where it is the warmest and presumably more humid.
The new 'blue label' LV ATF HP supposedly has a different friction package that does not pick up water from the air.
(There is a vent on all trannys to deal with the expansion/contraction with the warm/cool cycles with driving. So there is some normal air exchange in and out of the tranny.)
I say all that which is already out there from GM because..... seems to me that for ALL A8's, it is just a matter of time for moisture pickup in the ATF and shudder to occur. I have done TWO flushes on my own a couple of months ago with Mobil LV ATF HP, only to find out the fluid I put in is gonna pick up moisture too. (Bummer!!!!) So, all I did was reset the A8 'moisture shudder timer'. And any of you out there with an 'old flush'; you will need a new one!
This time around, I will see how great my dealer is, and try for a dealer flush with the 'blue label' fluid under warranty. Hopefully it's even way better than blue label scotch!!!
Old Jan 22, 2019 | 10:54 AM
Har-ray's Avatar
Har-ray
At my dealer now for new flush. 4 Vettes ahead of me.
Old Jan 22, 2019 | 11:24 AM
Har-ray's Avatar
Har-ray
Any feedback, good or bad, on the new flush?
Old Jan 22, 2019 | 08:07 PM
SingleTrackMinded's Avatar
SingleTrackMinded
Sixgun95, where you taking yours in for service at?
Old Jan 23, 2019 | 12:52 PM
Maxie2U's Avatar
Maxie2U
“Shudder, according now to GM info is related to the ATF picking up moisture from the air, thus changing the friction properties”. Where did you get this info from? Source please.
Old Jan 23, 2019 | 01:51 PM
FreeFlyFreak's Avatar
FreeFlyFreak
I found it various places, but the original source appears to be here, a dealer forum that quotes a GM document:
https://forums.dealersedge.com/viewtopic.php?f=3&t=11352&start=10
Old Jan 23, 2019 | 02:05 PM
FreeFlyFreak
It appears the actual TSB is now available online if you don't mind paying $15, personally I'll wait till it hits a free site to look at it.
https://www.repairprocedures.com/bulletins/document/18na355/5181942.html
Old Jan 23, 2019 | 02:06 PM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
I'll be taking mine in soon because my transmission is getting worse (rpm fluctuations, shudder) with only 10,000 miles and 1 year old....Stingray Chevrolet will be the servicing dealer.
Old Jan 23, 2019 | 02:31 PM
Stan0324's Avatar
Stan0324
I am the original owner of a 15. Received it 1st week of September 2014. Had zero problems with the A8. My warranty expired this year. I have talked with my tech (Paul Korner) and basically said if it's not broke don't fix it. I have about 13,000 miles on it. I am thinking that I should do the flush while it is still under warranty. This sound right?
Old Jan 23, 2019 | 03:09 PM
FreeFlyFreak
Do you live where it is humid or dry?
Mines a 2016 8300 miles no sign of shudder but it lived most of its life in the desert.
Im going to wait to do mine a while, at least a 6 months maybe more let the rush die down, let the techs get the new procedure down and the dealers get rid of old fluid that maybe used by mistake. It has a CPO warranty till 100k 2020 though so Im not pushed for time.
Plus I doubt they would cover mine under warranty because it doesn't display the shudder, dry fluid.
Hopefully they will eventually make it a recall vs a TSB.
I will have it in at the first hint of a shudder though.
Old Jan 23, 2019 | 06:01 PM
Maxie2U's Avatar
Maxie2U
https://forums.dealersedge.com/viewt...11352&start=10
Thank you for sharing!
I wonder if GM will issue a recall on the old fluid instructing the dealer to replace it with the new non-moisture absorbing fluid? But it may be the cost of replacing fluid in all C7s could be more costly than their cost to replace the torque converter and/or the transmission on cars that continue to shutter even after a fluid flush/fluid replacement.
Even if GM does not intend to issue a recall it sounds like we should as a preventative measure have the moisture absorbing fluid replaced on our own dime.
Old Jan 23, 2019 | 06:13 PM
FreeFlyFreak
Yeah, I am hoping for a recall too.
For now Im biding my time
2016 8300 miles car was in the desert till I got it.
At the first hint of shudder I will take it in.
If not before, on my own dime.
There is a link for the TSB online now but its $15 to look at it, and its not a pdf so I cant download it.
I did take about 20 screen shots though.
Link to $15 TSB 18-na-355 is here if anyone is interested, I am sure it will be available for free soon enough, there are different procedures for different vehicles in the TSB:
Old Jan 23, 2019 | 07:05 PM
Har-ray's Avatar
Har-ray
Default Flush success!!!
EXCELLENT! Just got 2017 Stingray back from dealer after the new flush,transmission oil, and reprogram. The transmission is perfect. No shudder, no hard shifts. It didn’t run this well when I took delivery 38000 mi. ago. Could not be happier. Thank you GM. It’s about time.
18 na - - -
Old Jan 23, 2019 | 07:09 PM
V Vette's Avatar
V Vette
18 na - - -
Great! What do you mean reprogram? Thanks
To A8 Flush
Old Jan 23, 2019 | 07:41 PM
Har-ray's Avatar
Har-ray
They reprogram the transmission into learning mode. The computer “learns” your driving habits.
Old Jan 23, 2019 | 07:47 PM
TSLAVette's Avatar
TSLAVette
Anyone know when the factory began filling with the new ATF?
Old Jan 23, 2019 | 10:03 PM
VNAMVET's Avatar
VNAMVET
So even if you replace the torque converter with an aftermarket one, you would have the possibility of the same "shudder" issue if you use the wrong fluid?
