C7 yearly differences
Old Feb 14, 2019 | 10:13 AM
Patman's Avatar
Patman
Another change is that in either 2015 or 2016 they added the motorized pull down for the rear hatch. There is also a minor change to the track mode display starting in 2018 as well (track mode display shows the actual temperatures now) They also revised the tire temperatures in 2018, before that I believe it only had four display settings (I think they were frozen, cold, warm and hot) and now there are five (cold, cool, normal, warm, and hot)
RapidC84B's Avatar
RapidC84B
Originally Posted by Deepdiver
Auxillary coolers were added to the Z51s in 2016. This a must have should you want to do any sort of tracking.
Only for the automatics. Manual is unchanged and has more than sufficient cooling. I track a 2014 Z51 M7 regularly.
Old Feb 14, 2019 | 11:05 AM
Judgment Day's Avatar
Judgment Day
Here's a picture of the 2018 Track Mode Display settings by Foosh on an unrelated thread:
Originally Posted by Foosh
This display below is one of the Track options, which I have selected all the time regardless of mode. It's new starting w/ 2018 models, and I love having all the vital stats up at all times.
Old Feb 14, 2019 | 11:39 AM
Maxpowers's Avatar
Maxpowers
Can you guys stop posting that pic. It makes me jealous.
Old Feb 14, 2019 | 01:53 PM
Judgment Day
^^^ It slipped.
Old Feb 14, 2019 | 03:54 PM
TXshaggy's Avatar
TXshaggy
Originally Posted by IPTV65
The Automatic transmission was changed from a 6 speed in 2014 to an 8 speed 2015-present.
Other than GS, Z06, and ZR trim additions this is the only significant change.
Old Feb 14, 2019 | 05:07 PM
17C7's Avatar
17C7
Originally Posted by Tool Hoarder
Basically no changes other than the flat bottom steering wheel in mid 2015 and later and some infotainment menu changes. The 2016 and newer body panels have different composition SMC with less glass content for a smidge less weight and for some reason 2015 and newer had a different axle than the 2014s (just learned that). 2018 late production and all 2019 went through the new paint shop where the panels are robot sanded before paint and the paint system is much better. However, looking at new ones on the lot the panel fit/finish is still all over the map depending on how much meth the UAW worker had in his or her system at assembly.
To add power pull down rear hatch 2016 and up and the A8 transmission in 2015.
Old Feb 14, 2019 | 05:19 PM
JMII's Avatar
JMII
Given how hard you have to slam the hatch the power latch / pull down seems like a great update to me.
I just learned in 2015 they added the "stealth" exhaust mode option, my 2014 only has Auto or Off.
Old Feb 14, 2019 | 07:08 PM
dbirdhouse1's Avatar
dbirdhouse1
Default well
Good info. Keep the differences coming if there are more.
'14s are older than '15s? I think these nice guys have pretty well hit them all (that's why I love this site)...
Old Feb 14, 2019 | 07:26 PM
joemessman's Avatar
joemessman
Stingray went to 19 and 20 wheels in either 2018 or 2019 model year. Previously 18 and 19.
Old Feb 14, 2019 | 09:57 PM
Patman's Avatar
Patman
Another significant change for sure! It was 2018, as mine came standard with the 19/20 wheel combo.
Old Feb 14, 2019 | 11:32 PM
Spitfire Mk1's Avatar
Spitfire Mk1
Formula 1
My dealer told me the A8 trans fluid is different in MY 2019.
Old Feb 15, 2019 | 09:55 AM
  #33
LIStingray's Avatar
LIStingray
In that vein, the oil that comes in the 2019's is now Mobil1 0w-40 instead of 5w-30.
Old Feb 15, 2019 | 05:50 PM
  #34
hummiscorvettetaken's Avatar
hummiscorvettetaken
I think the "push start" button went to chrome in 2016.
Old Feb 15, 2019 | 11:35 PM
  #35
Makitso's Avatar
Makitso
2019's have a stronger spider gears according to Tadge :
" We increased the load capacity of the spider gears in the differential through a different tooth profile. Although fairly expensive, that upgrade is in production on all Corvettes now. Our primary focus was keeping lube temps as low as possible for both the trans and differential."
https://www.corvetteforum.com/forums...sed-power.html
Old Feb 16, 2019 | 06:41 PM
  #36
sjw91's Avatar
sjw91
That display doesn't look the same on my 2019. What's the 4th bar that I don't have? I can see it's a temperature display, but I can't tell what for.
Old Feb 17, 2019 | 01:11 AM
  #37
The above display gives a heck of a lot of info. Nice change that the ‘18 and up cars got.
To C7 yearly differences
Old Feb 17, 2019 | 11:13 AM
  #38
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Somewhere along the line, I think they changed the center armrest leather and foam as the earlier models had issues with the leather winkling with indentations, however the newer C7s don't seem to have the same problem.
Old Feb 17, 2019 | 11:29 AM
  #39
CocoVette's Avatar
CocoVette
What changed as far as the axles from 14 to newer?
Old Feb 17, 2019 | 11:54 AM
  #40
pdiddy972's Avatar
pdiddy972
New, must-have, MRC calibrations for cars equipped with the magnetic ride. Those became common in 2018 and newer I think.
