I remember seeing them on GSCreations, VetteStripes, well as several other places. The GS has the same hood as the Stingray, so make sure that you don’t order the Z06 version.
I ordered the 2 layer version from Mike. The first layer was the 3m 1080 carbon flash and the actual skull was the 3m matte black.
You need the contrast to see it on a stinger when it is stock with no paint.I believe the GM gains it's contrast when it is installed on top of a Carbon Flash stinger.
I could be wrong?
I will be contacting Mike.I would like to install over my Stripes to be different.Gonna ask him his opinion on sticking and finish.Planning on just the Flat Black to contrast on the CF Stripes.
OP Good Luck with your decision
I could be wrong?
The yellow hood above is GM OEM with an owner added 1” Carbon Flash added to make it a tad wider.
