From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Originally Posted by Gearhead Jim
Installation was a PITA because I'd never taken the back of the trunk and speaker apart.
That was the easy part. Bigger issue for me was snaking the coax down through the gauntlet of energy absorbers that make up the bumper! Had to use a snake to get a messenger line down and then pull the coax (the C5 and C6 were much easier in that regard!)
If I had to do it over again, I'd use Ron's (gliot1) method.
Thanks. I called Ecklers and ordered the mount kit for the C-7 and it should be here in about 10 days. I'm a little nervous drilling a hole in the rear facia to get the cable through. Any pics would be helpful.
Super easy to do (you don't need to drill any holes in the outside fascia itself, just the inner liner. Do you have a coupe or vert?
Sounds like your install turned out really clean. Any chance you could shoot me pics of the area where you drilled through the back valance for the antenna cable, and the space where you put the unit next to the fuse box? Also, where did you have the pl59 extended cable made? Thanks for all your help.
You ordered just the mount from Eckler or their mount/antenna package?
Can't help with the pics as I didn't take any at the time but trust me, it is super easy. The hardest part of the whole job is fishing the cable down from where you drill your 1/4" hole, down to the existing opening behind the license plate (I used a piece of twine with a plumber's fish and then pulled the twine back up). The whole job takes less than 10 minutes to do.
You just pop the rear piece trim off the back (you don't have to completely remove it, just enough to get behind it to drill the hole and run the coax)
On the 2016-2017 models in our club, no one could find an easy way to drill through the rear of the interior tub to route the antenna cable out by the license plate. Everyone was removing that big rear speaker assembly before drilling.
Not sure if the later cars are different, or you found a better way to drill & route the cable.
The instructions that came with the Mid America kit were pathetically bad and even had a note something like "if you find a better way to do this, please let us know."
Jim, I didn't notice any difference between doing my '14 and my '19.
There is no need whatsoever to remove the sub woofer assembly. In fact, you don't even need to remove the trim piece completely either. I'll try to get some pics of the parts of the rear trim that need to be "popped" off but you only need do the top edge (that is under the weatherstripping) and move it out far enough to get a drill in (only takes an inch or two).
The hardest part of the whole job is fishing the coax past all the energy absorbers that make up the rear bumper and out the holes that already exist behind the license plate.
That's interesting, we had to remove/replace the rear speaker which is a PITA, but the actual fishing of the antenna cable was 0- we drilled down low from the outside and could see the end of the cable when we poked it through from inside.
It sounds like people have the choice of working to remove the speaker and having an easy time with the cable, or easy drilling but tough cable fishing.
I don't have any pictures of my installation from almost two years ago, and didn't try to remember the details, so I can't help a lot. But any pics you can post will probably be useful to others.
The instructions that came with our Mid America kit applied only to a 2014 coupe with the vent door at the back, for any other C7 the kit merely supplied some poor quality drawings of the trunk area from the GM parts catalog and let the owner figure out how to handle the cable issue.
Got a link2?
It is actually very easy to get the coax pulled. The back end is kind of a double layer of glass in back with a hollow between. I drilled a hole inside to out, just under the hatch latch mechanism. Behind tge license plate is a large opening to draw tge wire through. Dont fear removal of the interior panels. They all snap off, but have a strange feel when removing, as if they may break. They wont and are just mounted on snap fasteners. I found it much easier to remove the sub woofer. It is easy....4 screws, leave it plugged in and just set it down.
Originally Posted by Big Lebowski
The 1970's called, and they want you to stop using an outdated form of communication...
Trust me...As I'm a Ham (Amateur Radio Op) AND a Commercial RadioTelephone Licensee, using a CB is kind of an anathema to me BUT it is far superior to GMRS/Family Radio Service Handie Talkies for communicating between vehicles and an several different levels
(not to mention the number of states cracking down on using handheld devices while driving. )
Sincerely, whatever makes you happy...and thank you, as I had to look up "anathema" and now consider my vocabulary expanded! Cheers.
