Android Auto "Something went wrong, please try again later"
Old Mar 8, 2019 | 01:14 PM
cor66vette's Avatar
cor66vette
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
Default Android Auto "Something went wrong, please try again later"
I tried searching this forum and Google, so don't call me lazy for posting a thread ....
When I try voice command for directions with Google Maps or Waze using Android Auto, I get the audio message, "Something went wrong, please try again latter".
This I get whether or not the phone is connected to the car (2017 GS)
Voice command works fine making phone calls.
This is something that never happened before. Nothing changed in my phone that might affect AA.
I uninstalled and reinstalled Maps, Waze, and AA, also changed the usb cable.
Your help is appreciated.
Thank you
Old Mar 8, 2019 | 01:24 PM
Akcajunz's Avatar
Akcajunz
Veteran: Coast Guard
Have you updated your phone lately? Maybe a hard reboot of your phone? Just throwing things out there for you to try...Good Luck!
Old Mar 8, 2019 | 03:32 PM
defaria's Avatar
defaria
Maybe something when wrong. Did you try again later?
I know, I hate crappy error messages myself. So you're saying if you say "OK Google, navigate to 7-11" or some such it returns "Something went wrong"? If that's the case it follows that it's not AA that's causing the problem.
Or are you saying that you only get this problem when running AA (attached or otherwise) and do a voice command about directions?
I've experienced that occasionally you'll get a few "Something when wrong" when asking Google assistant about anything. As a large beast of servers running in the cloud, sometimes one of them goes screwy and asking again may get you another server who is not screwy. If you try again a few times does it continue to refuse to work?
Old Mar 8, 2019 | 03:36 PM
Rebel Yell's Avatar
Rebel Yell
Good luck, crap like this can be so aggravating.
dbirdhouse1's Avatar
dbirdhouse1
Default sorry.....
….try somebody else's phone (weak I know)?
Old Mar 8, 2019 | 03:49 PM
Exia's Avatar
Exia
Shutdown the phone for a few minutes and turn it back on. I get the occasional "something went wrong" message as well although its with Spotify as I don't use voice commands for my maps. Doing a hard reboot or power cycle of the phone always fixes the issue.
Old Mar 8, 2019 | 05:06 PM
defaria's Avatar
defaria
Exia, that's probably not the case. Most like this error is transient and not even on your phone. By the time you reboot the phone the problem has fixed itself. Your solution is like the Windows solution to everything - reboot. That's why I run Linux.
Saw this as an email signature and laughed my *** off:
Microsoft Windows has detected that your mouse has moved.
Do you want to reboot to effect changes?
Old Mar 8, 2019 | 06:57 PM
cor66vette's Avatar
cor66vette
@Akcajunz- Besides the usual phone updates that have gone on since day one, and like I said never an issue in the past, nothing is different with the phone or the car.
@defaria - I only get this problem when running AA (attached or otherwise) and do a voice command about directions.
It's just weird that this started happening out of the clear. Yesterday normal, today craps.
Thanks to all for your suggestions. I've tried 'em all.
Old Mar 8, 2019 | 08:08 PM
defaria's Avatar
defaria
So you're saying that you get this because you are running AA and it's either on your phone screen as the foreground app or you're connected and it's on your C7's main screen. How do you initiate talking to Google Assistant? Do you say "Hey Google" then ask for directions or do you tap the mic button on the phone or on the screen first?
When you are walking down the street and you are not running AA at all, what happens if you start Google Maps then tap the icon and ask for navigation directions?
Similarly when you are not in Google Maps, when you are on the home screen of your phone, assuming you've configured a search button on your home screen (often configured by default), what happens when you tap on the mic and ask for directions?
What happens if you're in your car and running AA, either on the phone or the screen and you switch to your home screen, tap that mic and ask for directions?
You see there are many ways to interact with Google and what I'm trying to determine is do all fail or do some work and some not work. Not all of them talk to the same Google Assistant. In the beginning, if you were in AA and asked for directions that's pretty much all you could get. Later AA and Google Maps were hooked into the Google Assistant. This means you can actually tap on the mic in AA and say "Tell me the latest news" and Google would play the latest news on your radio. Or you could ask for the weather or who's the president or sports scores, etc.
Needless to say are you sure you've been keeping AA, GM, and your OS up to date? I've had problems with the Play Store not be able to update my apps and getting stuck. Unsticking it required clearing of cache and data from the PlayStore, Playstore Services, and Google Framework services. It was a real PITA however I just got my new S10+ a few days ago and everything is currently snappy, connecting AA is fast and reliable and things like updating apps no longer have a problem in the PlayStore.
Old Mar 8, 2019 | 09:28 PM
cor66vette's Avatar
cor66vette
I tap the mic button on the phone or on the screen first
All works fine.
I only ask for directions when I'm in Google Maps or Waze
I haven't done that
Yes, everything is up to date, and even more so being I uninstalled and reinstalled the apps.
Thanks for the help.
Old Mar 9, 2019 | 12:16 AM
defaria's Avatar
defaria
Thanks for answering all my questions...
Looks like my work here is done. I just don't understand it though. I try to help. I ask questions to gather data. And people respond by totally ignoring them! Fix it yourself then... Geeze.
Old Mar 9, 2019 | 08:17 AM
cor66vette's Avatar
cor66vette
You confuse me with that response. Did I not answer your questions, and thank you or your input?
Old Mar 9, 2019 | 08:28 AM
Elk's Avatar
Elk
I am certain he is confused - like the name of the emoticon - rather than being sarcastic.
I see his answers to your questions. Do you not see his post #10?
Old Mar 9, 2019 | 08:41 AM
defaria's Avatar
defaria
Yeah, he hid his answer inside my quote, 'cept his last answer. Still, when I ask "What happens when you try X" and he responds with "I don't", he's been too difficult to work with. In my mind, it was clear that I wanted to know what happened and it was clear that he didn't want to tell me. What's not clear is why. He did this not once but twice! I'm not gonna ask again. I'm done.
Old Mar 9, 2019 | 09:28 AM
Elk's Avatar
Elk
I see your point.
I just hate to see someone offering help and not connecting with the OP. Thanks for the effort.
Old Mar 9, 2019 | 12:41 PM
defaria's Avatar
defaria
Yeah, when it starts being too much effort I look at seeing how much I'm getting paid for assisting then adjust the amount of help I offer... jk!
It looks like the OP is indeed having a problem but only when using voice command when in AA and GM running underneath. It would be interesting to see if he could return to his home screen then click the mic on the Google search widget and ask for directions since that appears to work for him outside of AA. He couldn't return to his home screen then fire up Google Maps directly because AA senses that and doesn't allow it. I know I've had times when for some odd reason something in my calendar would not show up in AA. I would go to my home screen and tap on the event in my calendar. Then I would tap on the address. This sends the request to GM. But under AA it flashes a warning saying you can't run GM on the phone when under AA however it still sends the address to GM running under AA and the route starts anyway.
Other than that I would think he might want to clear cache and data for AA and perhaps GM too. Uninstall AA and maybe reboot in order to make sure any services running in the background have also been stopped (or use a task manager to find and force stop such services to avoid the full reboot) then install AA again.
I did notice when I was having problems with my last phone and had to fix the PlayStore not updating apps by force closing and clearing cache and data for Google Play, Google Play Services, and Google Framework Services that many settings would be lost like all of my SmartLock settings and, interestingly, AA. When I would start AA after that it would go through the steps that you go through when you first install AA. So it was clear to me that at least SmartLock settings and AA settings were contained in the data of either the PlayStore, the PlayStore Service or the Framework services. He might try that too.
Old Mar 9, 2019 | 03:46 PM
triplblk91conv's Avatar
triplblk91conv
You might try to hold the button for about a second, not just press it quickly. This was said before in another thread about AA. Even in my
new 2019 GMC "how things work" instructions (on the GM phone app), it says there is a short press, and a long press, they will summon two different results.
Dan
To Android Auto "Something went wrong, please try again later"
Old Mar 9, 2019 | 06:41 PM
cor66vette's Avatar
cor66vette
Dan
Hey, Dan! You're the man!
Thanks for jumping in my thread.
Quick, simple, no fan-fare! All up and running.
It just takes one member who knows what's going on.
Thank you.
Old Mar 9, 2019 | 07:41 PM
defaria's Avatar
defaria
Wait! Does this mean you were mistaking the single tap on the of the mic button ON THE STEERING WHEEL from tapping the mic button on the phone or the main screen when running AA?!?!!!! And it said "Something went wrong"?
Old Mar 9, 2019 | 08:27 PM
triplblk91conv
Yes, use your steering wheel controls guys, it is all integrated! Voice commands for AA, iPhones AppleCarplay works the same. Keeps your eye one the road 😉
