Corvette power-steering recall affects 27,000 cars
shineocd (03-17-2019)
#63
According to this article... https://www.consumerreports.org/car-...ering-problem/
It affects Corvettes manufactured between these dates.
“2017 Chevrolet Corvette coupes manufactured from July 27, 2016 through May 4, 2017”
#65
It depends on how you interpret the article. Since my Vert is listed as part of the recall by GM, I interpret the article as 2017 Corvettes and 2017 Camaro coupes. It would be great if Verts were not part of the recall but I tend to believe GM over Consumer Reports in this case.
#66
How would 2017 C7 convertibles escape recall? They wouldn't. You're welcome.
#67
I would also believe the GM info over Consumer Reports info as well. As I stated in my earlier post the NHTSA site that's linked to the Consumer Reports article states my VIN# has 0 recalls, however the GM recall sites states I have (1) ( N172093460 Mechanical Trunk Release May Not Operate ) which is correct. Neither show my 2017 vert as being included in the power steering recall.
Or GM may have used a different control board for the verts.
#69
Just checked my build sheet. My 2017 GS Coup was manufactured 9/20/16 and IS on the recall list.
The thought of driving a car with a known safety defect which may raise it's head and a very inopportune moment is not comfortable.
#70
This means that even though yours may be in that range, chances are slim. GM probably established a safety range to cover all "possibly" affected.
Mine is in the range too, and so far it's running great, I have around 4000km on it. We'll see in the spring when I take it out of hybernation.
#71
Unless you are handicapped, this barely qualifies as a safety concern. In the unlikely event your power steering fails, the answer is to use both hands to turn the steering wheel.
#73
Yes, you would not have power steering, that is the worst thing that could happen. So low speed parking lot type maneuvers would be difficult. Also if someone only had the use of one arm or hand then this situation should be taken more seriously, otherwise it's not really a big deal in my opinion.
V Vette (03-17-2019)
#74
I just checked date of build on my 2017 Corvette, and it showed 3/17. I also compared my VIN#, and it said there were no recalls.
Just trying to get information out there, so maybe there will be some correlation between build date and recall.
Ken
Ken
#76
Had that done at dealer last fall, in and out in 30 minutes.
VH
#77
Received 2,051 Likes
St. Jude Donor '13
When GM had their ignition switch fiasco a few years ago, the sudden loss of steering assist was considered a factor in some of the accidents. Of course the airbags could also be dead, etc; but the point is steering surprises can lead to accidents.
#78
I move my corvette in the garage sometimes without starting the engine, the steering is hard to turn but the car is also not rolling at that point. It's doable.
I would guess that the biggest danger is not the added resistance the driver would feel but the surprise effect that might steal a few precious seconds away from your reaction time.
#79
St. Jude Donor '13
Yep, that's exactly my point.
Add to that the number of people who are texting/phoning/putting on makeup/driving one-handed. A jury will be highly sympathetic to the "victim", especially since they will deny doing any of those things I just listed.
#80
My 2017 Silverado encountered the same issue as people are discussing here, and they had to replace the rack/module whatever stuff too - not just a software issue for me.
