Pot hole damage
Old Mar 18, 2019 | 07:29 AM
N875ED's Avatar
N875ED
You may have broken one or more cords in sidewall of the tire. Get it checked ASAP.
Old Mar 18, 2019 | 10:51 AM
Just take the wheel in and have it checked. Sounds like a bent rim or a damaged tire.
Old Mar 18, 2019 | 11:28 AM
orca1946's Avatar
orca1946
I need to be more watchful in the future!
Old Mar 18, 2019 | 11:52 AM
Vette Ski's Avatar
Vette Ski
Originally Posted by Runflatred
Thanks but that was the first thing I checked. Wheel doesn’t look out of round either but really can’t tell just by looking at it.
Jack front end up , put a 2X4 or 2X6 on the ground next to the tire ( in front or back ), lightly touching it, spin the wheel watch if the distance changes between the two for a general idea.
Hope this helps!
Rich
Old Mar 18, 2019 | 02:36 PM
Runflatred's Avatar
Runflatred
Bringing it in to Chevy dealer tomorrow. Hope for the best.
Old Mar 18, 2019 | 03:24 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Hmm, checking would be OK BUT be careful about:
1) buying rims from a dealer
2) having a dealer install the old (or new if needed) tire.
Was talking to the Chevy dealer Service Manager where they did my Courtesy Delivery. Great guy and in this small dealer they have one C7 Tech and he is the only one to touch Vettes. I mentioned that the large Chevy dealer in my town won't touch low profile run flats. I mentioned that the Firestone store with 12 service bays and ~20 techs only allows 1 or 2 to fix flats or change low profile tires. He said he does the same. Won't waste his Techs time messing with them as if you don't do enough you can't do it fast enough to make money! He sends Vette and Camaro etc low profile tires to a local Tire shop.
You probably have a bent rim, alignment usually won't cause an instant vibration and the wide GS rims are known to bend. Tadge, the Vette Chief Engineer has posted on the Forum that bending is due to "potholes. Some don't accept that but my GS is 2 years old and without the freezing thawing issues "Up North," we have few significant pothole issues in Eastern SC. A bent rim will produce and out of round tire instantly! Does not have to be out much.
You can find OEM wheels on the Net cheaper then MSRP. You might even try Discount Tire who will get the wheels from a wholesaler and usually will give a reasonable discount.
Good Luck.
Old Mar 18, 2019 | 04:32 PM
cv67's Avatar
cv67
St. Jude Donor '05
Better to bend than break....one reason I avoid cars with rubber band sidewalls,some potholes will destroy anything though...irritating.
Old Mar 18, 2019 | 05:55 PM
DGA3's Avatar
DGA3
The governor of our state has proposed an increase in our gasoline tax of 20-30 cents a gallon to help fix the terrible roads.
They are bad, but that's going to really increase the cost of a fill-up of premium fuel!
I guess it's still cheaper than hitting a pothole or crack in the road and paying for a new wheel and/or tires.
Old Mar 18, 2019 | 08:35 PM
DALE#3's Avatar
DALE#3
Old Mar 19, 2019 | 12:26 AM
ALEXAMES's Avatar
ALEXAMES
Bent wheel is my guess. C7 oem wheels are made in China. Lovely
Old Mar 19, 2019 | 01:12 AM
Walt White Coupe's Avatar
Walt White Coupe
I'm old enough to remember when people said the same thing about "made in Japan". We don't hear much about "Japan Junk" anymore and like it or not "Made in China" isn't going away. These GM wheels were made in Taiwan. Most people would consider that China. And they are a work of art.
http://superalloyengineering.com/services/design/
Old Mar 19, 2019 | 12:29 PM
50th year's Avatar
50th year
2017 C7 of Year Finalist
I don't have a clue where mine were made, All I know for sure is I have had 4 bent rims so far.
Old Mar 19, 2019 | 03:55 PM
  #33
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Dude, swerve and straddle.....safely.
Old Mar 19, 2019 | 04:34 PM
  #34
rb185afm's Avatar
rb185afm
I’ve bent a OEM wheel, a forged mono block wheel, and a upper control arm bolt so far, hitting potholes.
Old Mar 20, 2019 | 08:24 PM
  #35
Carvin's Avatar
Carvin
St. Jude Donor '15-'16
First I've heard of a bent mono. Must be utterly vexing.
Old Mar 26, 2019 | 05:17 PM
  #36
Runflatred's Avatar
Runflatred
Default Holy cow
I hit a big pothole with my left front tire on my 2019 Grand Sport. I immediately felt vibration over 40 mph. You think I knocked the rim out of round or did I mess up the front end alignment? There are no obvious dents in the rim and it’s holding air pressure. Could I have messed up something worse? Thanks in advance folks.
So I just my car back from Chevrolet. Seems all four wheels were bent and the front end was out of alignment. The wheel repair and alignment cost me $1040.
Old Mar 26, 2019 | 07:41 PM
  #37
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Wow. That's a lotta dough for your repairs. Sorry to read about it.
Years ago I used to go up to LI regularly on all routes: north thru Bronx, city to BQE/LIE, Verrazzano Br. to Belt Pkwy. I was always in my SUV and wondered how strong it had to be. HAD TO BE. To withstand those roads with nary a scratch (altho I did get my alignment done twice a year). I gave it a lot of thought but I could not imagine what route to take to get to LI if I took my Vette and its 'factory' forged wheels and not ruin something on the car. So, I never took the Vette there!
To Pot hole damage
Old Mar 26, 2019 | 08:12 PM
  #38
Jmhornz71's Avatar
Jmhornz71
It wasnt my 15 but my 08 that I hit a monster pothole. I developed a small trans leak I couldnt stop. Took it to the dealer and the problem was hitting that pothole cracked the upper and lower radiator supports and the cooling line for the trans couldnt seal right . $1400 worth of damage most covered by insurance still counts as an accident on the policy
Old Mar 26, 2019 | 08:28 PM
  #39
Runflatred's Avatar
Runflatred
So now that I got my car back from the dealer I will wash it wax it and put it in the garage because I sure as hell cant drive it on my shitty roads. Nassau County, land of high taxes and super shitty roads.
Old Mar 26, 2019 | 09:47 PM
  #40
Cadigti's Avatar
Cadigti
Runflatred. I sympathize with you. I am from Queens. Back in the day Nassau county roads relative to Queens roads were paradise. My sister lives in Garden City Nassau County and the roads there today are worse than I remember Queens roads ever being. In 4 years and 22k miles she has had 8 tires and 8 wheels replaced on her Audi with her tire and wheel platinum coverage. I am picking up a new factory ordered Grand Sport next month and do plan to drive it up to Garden City in July. I will have tire and wheel insurance! DC and DC metro roads are a little bit better, but not much.
