My C7 convertible Corvette windows won't index, trunk won't open automatically, and the convertible top won't fold down in the back. Any help on fixing this?
Without knowing more, it could be a few of many things.
Re-indexing the windows. Check the trunk partition. or you may have a problem where the top is not completely cycled one way or the other. This can happen after a battery disconnect, or if your car had the seatbelt recall.
I had a similar issue on 2019 vert after battery disconnect. I pushed the top closed switch and the top latches cycled and DIC stated that the top was indexed then I was able to index the windows. Hope this helps you.
