Mounting an amplifier
Old Apr 5, 2019 | 04:23 AM
EZ2BEVILC5's Avatar
EZ2BEVILC5
Default Mounting an amplifier
Hello,
Can an amplifier be mounted behind the seat on the vertical part or is there something significant behind it that can be damaged?
Thank you
Old Apr 5, 2019 | 11:31 AM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Not much room behind the seats....
Old Apr 5, 2019 | 11:57 AM
DWillys's Avatar
DWillys
Originally Posted by EZ2BEVILC5
Hello,
Thank you
IDK about a vert, but on the coupe -no.
Old Apr 5, 2019 | 12:52 PM
JMII's Avatar
JMII
The gas tank is back there somewhere. Might be better off under the seat. Best bet is the rear of the hatch where the 2LT / 3 LT subwoofer is. If you have the 1LT then there is a large void there allowing the amp to be totally hidden. If your creative there is likely room under the floor of the rear hatch where the factory amp and lots of other electronic in the car are placed (battery, fuses, etc).
To correctly interface with the factory BOSE amp you need one of these OEM integration units:
AX-DSP-MOST1
NAV-TV M650-GM
PAC AP4-GM61
You can do it via a LOC (line output converter) but the results will be subpar as the Bose processing will still be applied to the signal. Thus you really don't want to amplify the Bose signal due to its bass volume problem and noise cancelling feedback issues.
Old Apr 6, 2019 | 12:57 AM
EZ2BEVILC5's Avatar
EZ2BEVILC5
Thank you....That is great information....
To Mounting an amplifier
