Help-brake light
Old Apr 28, 2019 | 07:32 PM
a/c man's Avatar
a/c man
Default Help-brake light
My driver side brske light is not working and my driver side front running light is off too.. any help would be appreciated thanks.
Old Apr 28, 2019 | 09:03 PM
RonC7's Avatar
RonC7
OP,
Your profile says you have a 2004 C5. What year are you asking about:?
This is the C7 forum...
Old Apr 28, 2019 | 10:02 PM
a/c man's Avatar
a/c man
Sorry i have a c7 now been a long time since the c5 haven't updated my profile thanks for your comment
Old Apr 28, 2019 | 10:13 PM
Gvnski's Avatar
Gvnski
According to my OM (2015 C7) fuses 39 and 40 under hood are for Left and Right headlamps respectively. You might check fuse 39 as my OM does not show a fuse for the Brake light.
Old Apr 28, 2019 | 10:18 PM
a/c man's Avatar
a/c man
You rock thats a good place to start thanks.
Old Apr 28, 2019 | 10:21 PM
RonC7's Avatar
RonC7
Here are some wiring diagrams I found. Fuse # may be different depending on model year. Please put some basic car info in your posts...
Rear brake light, and tail lights are the same led assembly. Intensity is varied by pulse duty cycle.
Old Apr 28, 2019 | 10:31 PM
a/c man's Avatar
a/c man
Thanks man i have a 2015 z51 14k on miles
Old Apr 30, 2019 | 04:17 PM
Gvnski's Avatar
Gvnski
Did you ever figure out your light problem? Inquiring minds want to know!
Old Apr 30, 2019 | 05:37 PM
a/c man's Avatar
a/c man
Yes i just checked fuses and unplugged bcm.pluged it back and it started working must have had a bad connection not sure what did the trick but im happy for now!!
To Help-brake light
