Has anyone with a Z06 or GS not suffered from bent/cracked wheels?
#41
Hold straight edge next to tire what to see if it come in and out. Mine did tires wore good except toe ruined inside tread on front. Mine were spun on balancer stand at back you could see with naked eye but we put a ruler next to rim to verify.
three out of four so how did I bend two fronts and left year and miss the right rear.
z51vett
Doug
z51vett
Doug
#42
Moderator
Received 3,764 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23
M7 Z06 w/Z06 gets extremely rigid in track mode, not only is street a bad idea I was informed that there are certain tracks you should not use it. I will be getting the update this year, have to see how it goes.
#43
No pressure loss, no indication of a bent wheel... until I saw it on the balance machine.
#45
No issues 2019 Z06.
#46
Received 4,045 Likes
Not me...I'd love to know how many with cracked / bent rims were in "track mode" at the time.
#47
Location: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
Received 1,473 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
2017 Z06 with 11500 miles. Nothing I can see as far as bends or cracks. No tire pressure loss and no odd vibrations. Changed tires at 8500 miles to all seasons. Nothing found wrong with the wheels at changeover. Car is in sport mode almost exclusively. Spectra grey wheels.
#49
This is not a mode issue. After it is bent, track mode could make it crack faster but this is a result of inferior wheel compound, run flat tires and 11 inches of unsupported cantilever weight on the rear wheels and 9 inches on the front!
#52
OP. You need to make a poll to gauge the issue imo.
And make sure its public.. not private so people who don't own one can't skew results.
#53
Driving in track mode/sport mode causes wheels to crack/bend. FALSE. This is not true. Drive modes have nothing to do with wheel damage.
My .02 is, the forces acting on the vehicle is a component of vehicle mass and speed. F = MA. Both these components do not change with the vehicle mode, so i don't see how driving it in track/sport mode contributes to wheels bending.
Please read the post below, a response from Tadge himself, the corvette's chief engineer.
Here is the thread and his response for the folks who are interested. Lets end this misinformation right here
https://www.corvetteforum.com/forums...s-bending.html
Morton1 (05-16-2019)
#54
The following 2 users liked this post by Kevin A Jones:
Jeffthunbird (06-01-2019),
MHE-Plex (05-16-2019)
#55
Now that's interesting:
I've actually clipped grapefruit sized speed bumps which pinched my tires on the driver's side but the wheels were fine. Had to replace both tires $1,000 because they had cracks inside but no damage to the wheels. I drive in Sport mode 98% of the time. Of course the roads in AZ are pretty good. Not many potholes.
#57
Almost all bending occurs on the inside portion of the wheel. This impact was done on the outside of the wheel which is far stronger due to the support the outside of the wheel gets from the spokes along the outside edge. The inside edge has no such support and is bent very easily.
GeoGS (05-17-2019)
#58
No issues as far as I know with my Z06 wheels. I still can't understand how folks are getting bent wheels without hitting anything. It's impossible it seems to me. Is the weight of the car just too great and they bend while parked?
