QuickJack arrived
Old May 25, 2019 | 08:08 PM
wilson1137's Avatar
wilson1137
Cruising
Originally Posted by JK 23112
If it is hydraulic, does that mean it requires some kind of compressed air system to function or is it merely electric where you plug it into the wall? I like the way they "store" by hanging on the wall of a garage. That would be very handy for me because I only have a one-car garage and already have shelving, racks, etc., etc., that take up space.
I definitely need to look into a set of these things.
It is all self contained with what you get in the purchase. it is controlled by a small power unit where you connect the hoses to and then to the individual lifts. the only thing you need separate from what's included is 1)some automatic transmission fluid to fill the resevoir 2) the ability to fill each lift with 50PSI. so whether you have a compressor/bike pump or whatever. and that's just a one time need, from then on it's all self contained
Old May 25, 2019 | 10:00 PM
Corpsvette's Avatar
Corpsvette
Veteran: Marine Corps
Love my 7000 because I also use it on my Chevy Avalanche. Have not used it on the Vette yet but will soon. I push them to the center of the parking space in the garage and park the Vette over them. No issues unless you are lowered. Best investment I have made. Used it today to replace my EVAP canister on the Avalanche. Easy and some what portable. Great investment for those that don't have space for a real lift.
Old May 27, 2019 | 12:28 PM
SingleTrackMinded's Avatar
SingleTrackMinded
Can anyone provide the exact height of the 5000SLX while flat?
Old May 27, 2019 | 12:38 PM
TNSQUIRE's Avatar
TNSQUIRE
3 inches
Old May 28, 2019 | 10:20 PM
SingleTrackMinded
Originally Posted by TNSQUIRE
3 inches
thank you
Old May 29, 2019 | 10:23 AM
Akcajunz's Avatar
Akcajunz
Veteran: Coast Guard
So for those of you with this QuickJack, do you trust it enough to get under your car or do you still put Jack Stands under for added insurance? Reason I ask is that I've only seen this jack in photo's, the locking mechanism looks a little suspect. I plan to go to a Costco and try to see one in person to see how herky it is. I will most like still make the purchase but use jack stands as added protection until I have built up my confidence in the jack.
Old May 29, 2019 | 10:33 AM
TNSQUIRE's Avatar
TNSQUIRE
I feel safe under the car. The jack and locking mechanism is solid. I'm not sure you will find this at a Costco store. I think it's an online item only.
Old May 29, 2019 | 10:41 AM
Akcajunz's Avatar
Akcajunz
Thanks for that! Is there anyone in the Pensacola, FL area that has one and would not mind showing it off??? I'm not a very good online buyer, I still like to touch and see whatever it is I am buying. Thanks In Advance.
Old May 29, 2019 | 08:05 PM
SingleTrackMinded
I would highly recommend you use jack stands at all times. YM (and Life) MV
Old May 30, 2019 | 03:05 AM
Zan Dad's Avatar
Zan Dad
I would highly recommend using the pucks the square blocks are useable but it’s not 100% contact nor level on the jack point within the chassis. I use all 4 points for raising the car, the locking system is very intuitive and safe. Using jack stands seems redundant and silly, especially since the system has manual safety features.
Old May 30, 2019 | 10:40 AM
kennyjames21's Avatar
kennyjames21
There's nothing redundant or silly about having as many backup safety measures as possible. I've seen a few posts where these things have failed.
Old May 30, 2019 | 10:52 AM
Mike Campbell's Avatar
Mike Campbell
I've been looking to buy one and I found the same one at Home Depot free shipped to my door was the best price. But, as for me, I'd but jack stands under it anyway. Just better safe than sorry.
Old May 30, 2019 | 10:59 AM
  #33
kennyjames21
It's all fun and games until a car falls on you...
Old May 30, 2019 | 12:54 PM
  #34
LongBeachNY's Avatar
LongBeachNY
^ This
Old May 30, 2019 | 01:08 PM
  #35
tractman's Avatar
tractman
2024 C8 of the Year Finalist - Modified
One of the best purchases I ever made.....I find myself using it more and more. Simple/quick set up and my Corvette is up in the air.
Old May 30, 2019 | 02:21 PM
  #36
Jeff V.'s Avatar
Jeff V.
Do you back up your jackstands with a second set of jackstands? Because that's basically what you're doing with this.
Old May 30, 2019 | 02:56 PM
  #37
JMII's Avatar
JMII
It's jack stands all the way down, just like turtles
My brother has a Quick Jack, I've watched all the videos about them... these units are solid and safe, so no jack stands needed.
To QuickJack arrived
Old May 30, 2019 | 03:26 PM
  #38
zcarmaniac's Avatar
zcarmaniac
Best purchase ever,,,I use the short blocks with my pucks,,,easiest oil changes ever,,,,,
Great clearence
Old May 30, 2019 | 08:39 PM
  #39
SingleTrackMinded
I need to research this. Was not aware of the Quickjacks manual safety features.
Old May 30, 2019 | 09:30 PM
  #40
Zan Dad's Avatar
Zan Dad
There are 2 manual lock positions, it has a free moving sliding bar when it goes up and you will set it at either position 1 or position 2. It is on the outer most part of the system. Go to the website they have a good video explanation
