Blank information screen
Old Jun 8, 2019 | 04:12 PM
joecarrion@verizon.n's Avatar
1st Gear
Default Blank information screen
Is anyone experiencing a blank information screen where the only thing that works is the back up camera?
Old Jun 8, 2019 | 04:39 PM
Vette Ski's Avatar
Vette Ski
Dementia setting in ?? sorry couldn't resist !
Rich
Old Jun 8, 2019 | 05:14 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Try a lowering cycle or 2 and see if that helps.
If not, pull the battery negative lead for a few minutes and reconnect
If not, contact your dealer
Old Jun 9, 2019 | 01:56 PM
Corpsvette's Avatar
Corpsvette
Veteran: Marine Corps
Someone had a great post that if the Info Center is raised and lowered numerous times it wears out the cable. I suspect that may be a part of your issue if the above remedies do not work. When I stumbled upon that post, I made a note not to store stuff behind it requiring the movement of the screen up and down.. Just another neat gadget that will require maintenance and fixing. Good luck.
Old Jun 9, 2019 | 01:59 PM
Michael T*'s Avatar
Michael T*
I do not use mine. It looks like a cable prematurely wears out.
https://www.corvetteforum.com/forums...cheap-fix.html
To Blank information screen
