OBD2 recommendations
Otherwise if you are looking to stay under $50, search on Amazon and look at reviews. There are a ton of cheap readers out there.
BAFX
with this Torque Pro
And under $20
Autel AutoLink AL319 OBD2 Scanner Automotive Engine Fault Code Reader CAN Scan Tool
https://d1y6jrbzotnyjg.cloudfront.ne...2XWKZ35EOVO4XA
Autel MD802
https://smile.amazon.com/gp/product/B0090B7M2O
MaxiDiag Elite MD802
Powerful, All Module Scan Tool
The MaxiDiag Elite 802 can read and clear codes on all available modules on domestic, Asian and European vehicles (1996 to present). Performs deep vehicle system coverage for all available electronic systems and access to the body, chassis, powertrain and on-board communication modules. The MD802 also supports all five OBDII Protocols and all 10 test modes.- 50 Plus Module coverage
- Read and erase codes on all powertrain, chassis, body and communication and information modules
- Compatible with most domestic, Asian and European vehicles (1996 and newer)
- Live Data Graphing for all modules
- One-click erase all codes feature
- Automatic VIN Acquisition
- Perform oil light/maintenance reset
- Perform electronic parking brake testing and maintenance
- Life-time of free internet software updates
- Report printing to document pre and post- vehicle repair status
Read and Erase Codes on All Available System Modules
Read Body Control Modules including BCM, Digital Radio, Standard Radio, Drivers Door Module, HVAC (Air Conditioning), Instrument Panel Cluster IPC, Seat memory module, park assist module, passenger door, occupant presence system, rear heated, seat module, rear HVAC module, remote control, door lock, roll over sensors signal, acquisition module, theft deterrent amplifier, oil light reset, central gateway, electronic ignition switch, immobilizer, overhead control panel, headlamp controller, power window controller, convertible top controller, wipers, steering column module.Read Powertrain Modules
Read powertrain modules including transfer case module, ATC fuel pump control module, FPC fuel injection control module, FICM Radar sensor control unit (auto cruise control), all wheel drive control VG transfer case module, electronic selector module.
Autel MD802
Read powertrain modules including transfer case module, ATC fuel pump control module, FPC fuel injection control module, FICM Radar sensor control unit (auto cruise control), all wheel drive control VG transfer case module, electronic selector module.Will it report on individual wheel speed sensors?
Thanks.
The cheaper ones usually won’t read all codes and/or allow to clear, require additional $$ to buy the premium app and only work on Android or IPhone (not both)
+3 on the BlueDriver ... just used in on my C7
It's very configurable for my needs with all my vehicles.
Anything more than that for now, I'll likely invest in HP Tuners.
