Wondering how difficult it is to remove and replace the lower rear bumper panel on the C7.
It looks like there are just a few bolts on the bottom (each side) and a couple in the license plate cut out.
If anyone has some experience, please let me know.
thanks
steve
The clips on the bottom corners can be a little tricky, but otherwise straightforward removal. I’ve done it 3 times now. Use plastic tool to remove the rear reflectors or they’ll get scratched. No need to jack the car up either. Link provided is a great reference.
BTW, the links were helpful. It was less than a two hour job, even at a repair shop.
I gave them the detailed links with the full instructions.
Thanks to Rick T
