Window sticker
Popular Reply
If it is a brand new car, then by federal law, they should not have removed it. I would go back to the dealer and make them aware that you were not given the opportunity to remove the sticker, nor was it given to you. The dealer should be able to either print one or should buy you one from the Corvette museum.
"The Monroney sticker is required to be affixed to the side window or windshield of every new car sold in the United States and can only be removed by the consumer (Chapter 28, Sections 1231-1233, Title 15 of the United States Code). A fine of up to US$1,000 per vehicle for each offense is authorized if the sticker is missing, and other fees and penalties are authorized if the sticker is altered illegally (including imprisonment).[4] The act does not apply to vehicles with a gross vehicle weight rating (GVWR) of more than 8,500 lb (3,856 kg)." (https://en.wikipedia.org/wiki/Monroney_sticker)
There is a QR code on your door jamb (2018 and newer). If you have a QR scanner on your phone, you can scan the code and it will list all the service parts identification codes that your car was built with. There are numerous sites that will decode the meaning of the 3 character build codes.
Rich
with my buddy Rich. Your dealer can get one. He's the one that lost it, and he should be the one that foots the bill for another. He can get you one from the Corvette Museum just as well as you can. Print out this thread, and use the info Null Pointer gave you. That should surprise your jackleg dealer sufficiently enough.
I thought the dealers could request a duplicate, and I found the following:
