C7 gas door hinge
Old Jul 17, 2019 | 12:23 PM
sbrigham's Avatar
sbrigham
1st Gear
Default C7 gas door hinge
Does anyone know what the purpose of the hole is in the hinge for the gas door. Can't figure out why they made that hole.
Old Jul 17, 2019 | 01:42 PM
Steve2150's Avatar
Steve2150
I believe that was where the tether was anchored when the C7 had gas caps
Old Jul 17, 2019 | 01:47 PM
USMCVETC7's Avatar
USMCVETC7
Did the C7 ever have a gas cap?
Old Jul 17, 2019 | 02:02 PM
robertbruce's Avatar
robertbruce
No it did not.
Old Jul 17, 2019 | 04:36 PM
Maxpowers's Avatar
Maxpowers
Weight savings LOL...
Old Jul 17, 2019 | 04:50 PM
JK 23112's Avatar
JK 23112
If I am correct, there is a "vent" hole in there to help prevent it from getting vapor lock or 'burping' when you put fuel in the car. Of course, I could be way off base - just the first thing that came to my mind. When I put gasoline into my 2017 Stingray, the pump often "shuts off" long before I have filled the tank. I have to remove the nozzle and put it back in about 2/3 of the way in order to be able to continue fueling the car. For some reason, this happens a lot at Costco and one of our local Shell stations.
Maybe it is the flow rate of their pumps or perhaps the design of their particular nozzle. No idea.
I just miss the good old days when the gas tank filler was under the rear license plate (more easily accessed from either side) and the filler hole was big enough to put the nozzle in with room for air.
Old Jul 17, 2019 | 04:51 PM
JK 23112's Avatar
JK 23112
Uh oh. Nevermind. I was looking at the photo on my phone and thought the "hole" was something else. I get the fool award today.
Should have looked on my laptop first. Doh!
Old Jul 17, 2019 | 06:10 PM
My 2014 does not have a gas cap. I would agree that the hole may be some sorting a vent.
Old Jul 18, 2019 | 10:15 AM
sjw91's Avatar
sjw91
As suggested before, it probably was there for a gas cap tether before they made the decision to go capless. Sometimes designs go in different directions as they develop the car. The hinge design was probably already approved for production and not worth redesigning for the final configuration.
Old Jul 18, 2019 | 01:05 PM
JMII's Avatar
JMII
Is this part shared with another GM vehicle that has a cap? It might be a common mold. Or it could be something that allows the piece to be installed easier / faster, IE: an alignment jig or tool goes there during assembly.
To C7 gas door hinge
