Battery
If you're looking for a battery that will last longer, you should consider replacing it with a Lithium-Ion battery.
They last 2-3 times longer on average, but sometimes even longer. 10 years is not unheard of.
Not only do they last longer, but they are also more powerful and MUCH lighter. You can drop 30 lbs.
So if you're looking to shed some weight too, we have the perfect battery for your Vette.
https://antigravitybatteries.com/pro...tive/ag-h6-rs/
It is a direct replacement, and it comes with full Battery Management System, over-charge and over-discharge protections, thermal protections, etc. And of course, it comes with our RESTART technology (wireless jump-starting) that will ensure you never get stranded with a dead battery again. No jump-starting, no push-starting or time-wasting on a dead battery. Simply press the Restart button on the Keyfob and start the car as usual! And if something ever goes wrong, there are no acids to ruin your engine bay. Plus, you get a piece of mind with our 5 year warranty.
If you have any questions, please feel free to ask.
Regards,
$700-$900 and you only get a 5 year warranty? Wow. I'll pass.
BTW, I only had mine on a tender a couple times when I was out of town for a few weeks.
If you are thinking about your battery then replace it.
Am on my 6th Vette - more than 800,000K miles - never needed a jump start in 29 years - maybe tomorrow, but not as of today....
Our products does quite a few things..For example you will see .the Real Time Voltage without even being in your car. No need for a Multi-Meter. You get a real-time numerical and graphical representation of that real-time voltage over the previous 5 minutes, as well as the previous 31 days of historical data of voltage broken down into an easy to use Phone App. It also has a Starting Test that shows how low your voltage went during the start attempt, which is a good indicator of battery performance and age, as well as a basic Alternator Charging test.
The 31 days of Historical data is very useful because you can actually see the full 24 hours of voltage data during all times the car is sitting or being driven.... so you can see how fast the parasitic drain draws down your battery over the course of days or weeks, you can see if and when any electrical accessories like ON-STAR kick in because you will see in the graph the Load on the battery. It also sends you warnings to your phone if your battery is low so you know to put it on a charger. So its a really good accessory to have but also great for basic diagnostics. You could even tell is someone took your car out without you knowing about it since the voltage will show the car start and when driving the alternator puts out a higher voltage which you can see. It give the exact time and date of any moment that you choose to review.
Below are some screen shots.. The first is the first page where you can see the real time voltage and a graphical representation of the previous 5 minutes of data which would allow you to see what might be cause a draw as you are testing the battery...
The lower Screenshot show one day of the 31 days of historical voltage and you can see the charging curve when driving you can see the resting voltage of the battery and by reviewing that data in the time line you can know how long you drove the car for, when you stopped, at what voltage the car was charging at, if you had any spikes in voltages and more. So it a very nice and simple to use Phone App for those who wish to monitor their battery.
I have a video below that also...
Battery Tracker by Antigravity Batteries. Bluetooth Wireless Battery Monitoring.
Battery Tracker 24hours of Voltage Data
