Driving mode question
Old Sep 15, 2019 | 04:16 PM
Red08's Avatar
Red08
Default Driving mode question
For example, when I switch from Touring mode to Sport mode, the suspension is more firm or stiff. What exactly is going on to change the dynamics of the suspension?
Old Sep 15, 2019 | 04:18 PM
RonC7's Avatar
RonC7
The shock oil contains magnetic particles. Different drive modes change the magnetic field around the shocks which causes oil viscosity to change. Higher viscosity = stiffer shocks.
Search "magnetorheological dampers" for more info.
Ron
Old Sep 15, 2019 | 06:09 PM
Red08's Avatar
Red08
I wondered about that, but my vette doesn't have magnetic ride. According to your response, then it still has magnetic particles in the shocks.
Old Sep 15, 2019 | 06:13 PM
RonC7's Avatar
RonC7
No, you have coventional shocks without the fancy oil if you don't have mag ride option.
Ron
Old Sep 15, 2019 | 06:16 PM
roadbike56's Avatar
roadbike56
St. Jude Donor '16-'17,'22,'24
exactly what model Corvette do you have, GS, Z51, Base, Z06?
Old Sep 15, 2019 | 06:31 PM
owc6's Avatar
owc6
No, and your suspension should not change at all; only throttle response, steering, and the way the Nannies work should change with the turn of the dial.
Old Sep 15, 2019 | 06:36 PM
Silver C7's Avatar
Silver C7
I don’t have mag ride and the ride in sport is definitely stiffer and rougher than the ride in the generic tour mode.
Old Sep 15, 2019 | 06:38 PM
owc6's Avatar
owc6
Placebo effect.
Old Sep 15, 2019 | 06:39 PM
Elk's Avatar
Elk
Unfortunately this is placebo.
Old Sep 15, 2019 | 06:47 PM
goldend's Avatar
goldend
You might just be feeling the tighter steering when selecting the Sport and Track modes.
Dennis
Old Sep 15, 2019 | 07:16 PM
Elk's Avatar
Elk
Very good point.
Old Sep 15, 2019 | 08:07 PM
Red08's Avatar
Red08
I have the Z51 pkg, and I am certain that it does not have magnetic ride, but when I switch from Touring to Sport mode, the suspension is a bit stiffer. I will check to make sure. What is the 3 digit code for the magnetic ride option?
Old Sep 15, 2019 | 08:13 PM
Oh Boy's Avatar
Oh Boy
Sure way to tell is to open the hood and look at the top of your shocks. If there is a black wire coming out you have magnetic ride.
Old Sep 15, 2019 | 08:31 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
Hey bud,
FE4 - Magnetic Selective Ride Control
Old Sep 15, 2019 | 09:24 PM
dbj216's Avatar
dbj216
Aren't electrically adjustable shocks quite common anymore? I don't think you need the GM magnetic ride shocks (which are premium pieces) to get adjustability from the cockpit. Even Polaris side by side UTVs have adjustable shocks. Maybe someone who had had the shocks off the vette can clarify for me. I do know the Z51 option had adjustable shocks between street sport and track settings. I believe mag shocks are an option on top of the Z51.
David
Old Sep 15, 2019 | 09:36 PM
RonC7's Avatar
RonC7
I'm happy for your Polaris. Corvette C7 adjustable shocks ARE the mag ride shocks. They are black and have a wire coming out of the top. Conventional shocks are yellow. Z51 without mag ride does NOT have an adjustable suspension.
Old Sep 15, 2019 | 09:45 PM
Elk's Avatar
Elk
Magnetic shocks are an option for the Z51.
To Driving mode question
Old Sep 15, 2019 | 11:11 PM
Guard Dad's Avatar
Guard Dad
Correct
Guard Dad's Avatar
Guard Dad
Correct again.
Old Sep 16, 2019 | 12:25 PM
JMII's Avatar
JMII
Here is what changes... notice some things are optional.
Also Link to Drive mode must be on, because some of these settings can be overridden with manual settings.
