AFM lifter failure. Common?
Old Oct 1, 2019 | 11:32 PM
LT4CMG's Avatar
LT4CMG
Originally Posted by goldend
The following excerpt is from an article published by Super Chevy "Getting to Know the LT1 - Part 2:
The LT1’s Active Fuel Management (AFM) system uses ECM-controlled deactivation lifters to shut off cylinders 1, 7, 6, and 4, creating a virtual V-4 with an 8-2-5-3 firing order.
Dennis
Thank you. Very helpful
Old Oct 1, 2019 | 11:37 PM
LT4CMG's Avatar
LT4CMG
Originally Posted by vettetwo
Curious if oil change intervals plays a role in AFM lifter failure. Have oil change intervals followed the OLM recommendation, or earlier as many tend to do?
7200 on my 16 z51 drysump. 500 mile oil change in late 16, put the car away for the winter. I keep track of oil changes, do my own ever since the mandatory dealer 500 mile one. 4 oil changes in 6,700 miles since the 500 mile one. I check the level often, have never added a drop. About 9.25 quarts gets me exactly where I need to be on the dipstick. Always mobil1 full synthetic 5 30.
Old Oct 2, 2019 | 06:48 AM
L8ter's Avatar
L8ter
Would disabling the AFM with the Range device make any difference in these situations?
Old Oct 2, 2019 | 10:05 AM
HooosierDaddy's Avatar
HooosierDaddy
With an A8 Trans? Yes and my dealer recommended putting one on the car after it was rebuilt. If you don't have one, get one for the cheap insurance and who wants a 4 cylinder corvette?
I believe the M7's don't go into AFM unless the car is in ECO Mode, so if you have a manual you can just avoid that setting. However; I think the OP has a manual... so would it really help if it's still happening when not using AFM
Old Oct 2, 2019 | 10:11 AM
fugly1's Avatar
fugly1
This is correct.
Old Oct 2, 2019 | 10:39 AM
z51vett's Avatar
z51vett
My m7 has to be in echo mine is auto, oil changed about every 3000 miles Mobil 1 5w30. No track use on my car.
z51vett
Doug
Old Oct 2, 2019 | 10:47 AM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
We do lifter replacements frequently, but not just on the C7. The lifters are the same in the trucks, SUVs. Camaros etc. It's more common for the AFM lifters to fail, but it doesn't have anything to do with how little or how often it's in 4 cyl mode. We've done AFM lifters in cars with range modules so contrary to what the forums continue to regurgitate, it won't prolong the life of your lifters (or your torque converter or...).
To clarify, AFM is cylinders #1 and #7 on the left bank and #4 and #6 on the right bank. Over the years we've seen failures on any of those cylinders so I wouldn't say that one is more common than the other.
Old Oct 2, 2019 | 11:12 AM
SilverGhost's Avatar
SilverGhost
Assolutely! The RANGE AFM DISABLER electrically turns off the AFM switching gear. The AFM lifters never collapse, so AFM lifters never have the moving parts inside them moving, said moving which can accelerate failure.
But maybe you dislike the name RANGE. Do you like the name Lingenfelter Performance Engineering. when associated with corvettes? They can make AFM go away for you cheaper than RANGE, WITH some sweat equity on your part:
https://www.enginelabs.com/news/tech...delete-afmdod/
But the best way is to get those wonky AFM lifters out of your car, period:
https://help.summitracing.com/app/an...ment-%28afm%29
Old Oct 2, 2019 | 11:29 AM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Dennis
Thanks for the info. Seems my source wasn't........accurate
Old Oct 2, 2019 | 12:43 PM
jbenderl's Avatar
jbenderl
What are your symptoms?
I have a loud tapping noise from cold starts, left side. It goes away after about 5 minutes of driving. I haven't left it at the dealer yet overnight to recreate...
Old Oct 2, 2019 | 04:15 PM
LT4CMG's Avatar
LT4CMG
Find a dealer mechanic you can trust and have them look at it. The less pronounced knocking/tapping is what got me. Mine never got anywhere as loud as the video posted on page 1, but it certainly is a noise that's not your normal lifter tick you hear on many v8s. Lucky for me, the check engine messages kicked on as the mechanic was already looking for the source.
Old Oct 2, 2019 | 06:22 PM
weezon's Avatar
weezon
What would this cost without warranty?
Old Oct 2, 2019 | 06:40 PM
  #33
LT4CMG's Avatar
LT4CMG
No clue. If my cam is scored, then even more parts and hours of labor. But I do know that my plans for a supercharger this winter are now scrapped. I still have 2 yrs of PT warranty remaining, and kissing that goodbye by voiding my warranty with a SC install would be stupid on my part. Not what I expected to deal with on a 7200 mile car, I've lost confidencein my car, but hey, **** happens right?
Old Oct 2, 2019 | 06:50 PM
  #34
LT4CMG's Avatar
LT4CMG
Originally Posted by fugly1
This is correct.
And being my car since it had 6 miles on the clock, I can tell you with 100% certainty that it has never entered eco mode.
Old Oct 4, 2019 | 10:04 AM
  #35
LT4CMG's Avatar
LT4CMG
Update: parts finally trickled in last night so he started working on it. Called me this morning to tell me there’s some minor scoring on the cam. He ordered the cam this morning, but due to the strike, we have to wait and see. I told him he has my blessing to install a GM Performance cam if he can’t find the OEM one.
Old Oct 4, 2019 | 10:09 AM
  #36
HooosierDaddy
Glad it's getting sorted out for you! Cam upgrade and delete the AFM would be perfect... but warranty and all!
Old Oct 4, 2019 | 11:18 AM
  #37
DugT's Avatar
DugT
I just read the link about plugging the AFM oil holes and my interpretation of it is it does not turn off AFM so you would still need Range. Plugging the oil holes used by AFM just prevents risk of an oil leak in the AFM oil network. “If you do not, (plug the holes) you may have significant internal oil leaks that can result in problems with low oil pressure,” says Jason Haines of Lingenfelter Performance Engineering. Does this risk increase if AFM is turned off with AFM? It is possible that I misinterpreted the article but logically I don't see how cutting of the oil supply to AFM would disable AFM before the AFM failed because of lack of lubrication.
The oil path plugging tool costs $95 and I think you have to take the heads off to get to the holes. That isn't much cheaper than getting Range.
I hope RitchieRichZ06 explains how the AFM can fail if the AFM is turned off.
To AFM lifter failure. Common?
Old Oct 4, 2019 | 10:12 PM
  #38
v26278's Avatar
v26278
Good overview of the system and the typical cause of AFM failure here:
Even if you never properly engage AFM, the system itself could still malfunction. It’s not hard to imagine one of those “VLOM” solenoids going haywire and causing a mis-timed event. In the video, it’s SOP to replace the VLOM if an a-f-m lifter packs it in.
Old Oct 4, 2019 | 11:08 PM
  #39
LT4CMG's Avatar
LT4CMG
https://m.youtube.com/watch?v=mkly7XmMsOs
Thanks, so really no escaping this bs unless you eliminate the AFM system by rebuilding the motor to eliminate all AFM lifters and then reprogramming the entire ECU. Otherwise, this can happen at any point in time to any of the AFM lifter sets.
Old Oct 4, 2019 | 11:49 PM
  #40
DugT's Avatar
DugT
After watching the video three times, I have a different interpretation of it. My interpretation is:
1. In normal 8 cyclinder operation, springs hold the solenoids shut. As long as they are shut, everything is relatively safe.
2. The system is most vulnerable when switching AFM on or off. Any mis-timing of a solenoid can cause a lot of damage.
3. Other things can cause mis-timing. For example, low oil pressure.
If you turn the AFM off via software like Range, you avoid mis-timing because the solenoids are always forced shut by the springs. The solenoids would never receive an electrical signal to open. Did I miss something?
