Cylinder bank 7 AFM lifters have failed. The dealer engine guy is vette certified, and has been with them for 20+ years. So I’m not worried about his work, extremely knowledgeable guy, but I am wondering if this is a known issue or just a fluke. His recommendation is to replace all of the lifters on that side and also the fuel pump as he believes it is not functioning properly. Thanks to the strike though, we need to wait for parts.
If the mechanic is familiar with GM V8 engines it really doesn't matter whether he is Vette certified or not. As for AFM lifter issues I believe they are generally a thing of the past. The early AFM truck engines had AFM lifter issues that are pretty well discussed on various forums but the newer Gen 5 engines (like in the C7) seem to be generally free of issues.
Thanks guys. I’m really not that worried about the job itself, the guy’s great at what he does. Now I’m wondering if anything I did lead to this. I doubt it, as I remember friends with previous gen Tahoes and trucks with these issues.
Yes, and we are not alone! I believe it's the same #7 for most of the cases @KenHorse had a failure as well, but I don't know if it was the same issue.
Thanks for the link Ken. Your receipt seemed to indeed indicate #7. Can't wait until they get the damn parts. Although, in the meantime, they gave me a new 3.6 Blazer off the lot. Holy crap, this thing is unexpectedly quick
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
I'm even more confused. I haven't looked at for a while.
Now I know cyl's 1, 3, 5 and 7 are front to rear on driver's side and 2, 4, 6 and 8 are on the passenger side. I've been told that cyl's 3, 4, 5 and 6 are the AFM ones. So a non AFM lifter failed????????????
It shows lifter #7 not cylinder #7. I haven't looked at for a while.
Now I know cyl's 1, 3, 5 and 7 are front to rear on driver's side and 2, 4, 6 and 8 are on the passenger side but I wonder how valves (and lifters) are numbered. I've been told that cyl's 3, 4, 5 and 6 are the AFM ones
Are you happy with your car? Is your confidence back? My plan this winter was to install a supercharger, but this put an end to that plan. I'm going to wait one more season with my factory warranty, then I'll look into voiding that with a supercharger
Quite happy. No further issues since (8800 miles on the clock now)
While it may be a little more common sounding here, it's not very common to see this. We tend to see far more people post once an issue comes up vs not at all if their cars runs perfect.
Ken is an obvious unfortunate exception since he's a huge contributor here, but all the same. Playing it safe and never going into eco on my M7 tho!
As far as your confusion Ken, I’m no expert, not sure which cylinders are AFM, but I can tell you my service guy told me AFM lifters on 7. I’ll be talking to the engine guy again in a day or two. I can confirm. I find it ironic that yours was 7 too. Sounds like Hoosiers was too.
I don’t beat on my car, but with that M7 of mine, I doubt I’m ever in eco mode. The only eco I do is idle at red lights. Rest of the time, if my vette is out, it’s being driven, not eco-moded. I guess I might have to start looking at that idiot screen showing V8/v4 as opposed to my usual G meter screen.
Yes, I was only pointed in that direction when another member on here texted me videos of her 2016 with the same #7 failure. Dealer found the same issue on mine. She ended up with a Lemon law buy back because of how long it took and she developed torque tube issues.
For me the dealer was great to work with and the car ran perfectly after the rebuild... but more importantly it actually ran and pulled better than before the failure
Good luck with your car, I'm sure they'll get you back up and running. Timing sucks for the end of the year though!
The following excerpt is from an article published by Super Chevy "Getting to Know the LT1 - Part 2: The LT1’s Active Fuel Management (AFM) system uses ECM-controlled deactivation lifters to shut off cylinders 1, 7, 6, and 4, creating a virtual V-4 with an 8-2-5-3 firing order. Dennis
Curious if oil change intervals plays a role in AFM lifter failure. Have oil change intervals followed the OLM recommendation, or earlier as many tend to do?
