In more than 800K miles in Corvettes over the last 30 years I have not needed to have a car jumped. In fact, in more than 63 years of driving and owning cars on five continents I've had to have cars jumped twice.
4th: I hope you enjoy your trip to wherever it is.
It's a good feeling knowing you will be able to start you car up at 11:30pm rather than even having that as the least little inkling in the back of your mind during your vacation.
Unfortunately, having a 'new' battery is no guarantee that it's going to start your car as new batteries have a fairly high defect rate due to their substantial weight and issues with packaging/handling/shipping them.
Just to be safe, I would install a new battery 5-7 days prior to leaving on a trip as opposed to day of or day before. Typically if a new battery last a week you are out of the woods as far risk of pre-mature failure.
I offer this advise based on my experience buying/selling/warranting hundreds of thousands of batteries through my autos parts stores over the years.
That's good advice. I make sure any required services are done about a week before leaving a trip.
From: S/W ,Fla-Ohio State Football isn't a matter of life or death,Its Much More serious than that
Originally Posted by FLEXjs
It's my 3rd Corvette and I've owned over 30 cars in my life and never once replaced a battery that wasn't in need of replacing just because I felt like it was time. Never heard of anyone else doing that either.
I've never had a battery just suddenly fail without warning. If OP was worried, jumper cables are a lot cheaper for peace of mind.
See my avatar. C7 Z06.
I never consider replacing a battery until it hits the 5-6 year mark. Unless in severe climate, you're leaving $ on the table replacing prior to 5 years old and it's a fools bet gambling a battery will last much longer 6 years.
It's not uncommon for a battery to fail without any warning especially one with age on it, and jumper cables will not always start a car with a failed battery. Cables won't start a car where the battery is shorted out for example.
Well I guess if you always replace perfectly fine batteries arbitrarily then you wouldn't.
Can't recall the last time I ever had to have a car jumped either. I just said having a set of jumper cables in the trunk in case of a battery issue is cheaper than replacing perfectly good batteries.
A C7 with 91K miles and 62 months in Texas, where it's hot - and car never on a tender - is exceptional..... at 78 years of age and tending to leave cars in short-term airport parking lots for up to 3+ weeks I'm not going to arrive at X-hour to learn that my car won't start because of trying to save, what? $19?
You appear to be on of those sorts that divides the check out to the last penny, rather than just tossing $40 on the table along with the other folks and leaving in a good mood....
Reason: syntax
LULZ. I never split a cheque. I always pick up the tab.
I'm not a cheap kunt I just don't understand buying car parts that don't need replacing yet.
Spark plugs don't leave you stranded in a parking lot and never do all 8 fail at the same time.
Right. I'll change that to the serpentine belt!
By the way, I changed my battery at 30 mos, and will do it at 36 months on the current one. It has a 42 month expectancy. Cheap insurance considering the cost of a battery.
I've owned over 30 cars in my life and never once replaced a battery that wasn't in need of replacing just because I felt like it was time. Never heard of anyone else doing that either. I've never had a battery just suddenly fail without warning. If OP was worried, jumper cables are a lot cheaper for peace of mind. C7 Z06.
You have heard of it as of now. I have owned 90 cars and trucks in my life and learned long ago to routinely replace batteries that are 3-4 years old for those vehicles I keep for long periods of time. I always replace the batteries on my wife's cars at the 3 year point no matter what because I never want her stranded somewhere because of a battery issue. I may go to 4 years with my vehicles but never longer. In today's world of crazy people on the road, a highly reliable battery is a basic safety requirement IMO. I have the same view about tires and change them long before other people normally would.
I have had several batteries fail without warning. A good example was a 4 year old battery in a 2000 Impala. Went to start it one day and heard a loud pop under the hood. Battery completely dead. Looked under the hood and the battery had cracked right down the middle. Jumper cables or a jump box would not have been any help.
From: Between Forest Lake and White Bear Lake in the Land of 10,000+ lakes
Originally Posted by JackTBear
If you can get 5 years on an auto battery in the South Florida heat you must have Avenger powers.
And if you can't get at least 8 years on an auto battery in Minnesota's short summers, you have bad luck. Just over 12 years (145 months) is my best battery in a daily driver car.
