Performance exhaust
Old Oct 18, 2019 | 09:45 AM
Army pops's Avatar
Army pops
Cruising
Default Performance exhaust
I’m a new 2019 Stingray owner and would like to upgrade to the performance exhaust. Is there a means of making this upgrade?
Old Oct 18, 2019 | 06:41 PM
dbirdhouse1's Avatar
dbirdhouse1
Default Not easy
If you're talking about the factory two stage exhaust, unless it came equipped going aftermarket will be tough; I have a 1LT with the stock base exhaust so
I had it replaced with a Corsa Sport. Not as loud as the Corsa Extreme but suits me well over the long run...good luck
Old Oct 18, 2019 | 06:52 PM
lakemg's Avatar
lakemg
You could easily add the stock performance exhaust, but it will be in track mode the whole time which isn't a bad thing. If you plan to retain stock exh manifolds and cats, you'll want it in track mode all the time anyway.
Old Oct 18, 2019 | 06:56 PM
Yeah, the factory NPP exhaust in the Track (open calve) mode sounds very good.
Old Oct 18, 2019 | 09:13 PM
Army pops's Avatar
Army pops
Cruising
Default Exhaust
So if I go with the performance exhaust, do I need to change the whole exhaust or are there certain common items which limit the parts that need replaced.
Old Oct 19, 2019 | 12:06 AM
Frankie2blue's Avatar
Frankie2blue
Is there a drone issue in track mode like there was in the C6 with the valves open?
Old Oct 19, 2019 | 03:46 AM
yokennyr's Avatar
yokennyr
Following
Old Oct 19, 2019 | 06:42 AM
JDMilw's Avatar
JDMilw
There's been a lot of interest in the AWE exhaust products lately. Might want to check them out.
Old Oct 19, 2019 | 10:13 AM
lakemg's Avatar
lakemg
Not with the factory exh manifolds and cats. If you add long tubes + high flow cats, you can get a little bit of drone, but you almost have to try to make it happen.
To Performance exhaust
