C7 GS 2017 cracked wheels
C7 GS with 44k miles with a cracked wheel. I started noticing a rear tire leak that progressively became worse. Traveling, I took the car to the GM dealer in Las Cruces, NM. They did a typical tank test, could not find a leak and pumped the tire back up. Waited an hour for a leak. All good. Woke up the next morning and it was flat. The dealer did a full submersion test and the leak was in the wheel at the bead. This was the 20" rear wheel. I was reading the forum and notice a number of complaints about these wheels being defective, so I asked if there was a recall. No, and it was not covered because I am over the 36k bumper to bumper warranty.
The bill was going to be $900+. Because I read about the wheel potentially cracking and being warped, I opted to order in a set of C7 racing wheels that are high speed certified. Not too much more to buy four new wheels than one OEM wheel. So, we got the tires off and I was able to see the crack and that there was no road damage to the wheel. The crack was a strange vertical cleave indicating a casting problem. I quick check with a friend in the aluminum wheel business and his prognosis was a factory defect.
The reason for my post is to educate that a high-speed wobble or a leaking tire could be the wheels. I understand that there is some sort of lawsuit as well.
Name on the wheel is RONAL dated 22 June 2016
Bob
Bead Crack
Bob
Bead Crack
Register with the lawsuit attorney's for when damages are paid out:
https://topclassactions.com/lawsuit-...ys-rims-crack/
Update: new wheels
I was able to get the car out for a high speed run after the new wheels. Clearly there is a significant improvement in the areas of vibration and smoothness. The. Full range between zero to 💯 is significant both in the interior noise and in the butt. I am now convinced that the wheels were not true as well as the leaking crack in the rim. The difference is palpable.
I have a long history of wheel and tire problems going back to the first week owning the car. The dealer misaligned the car using a FE4 setting instead of the FE6-7 setting. This prematurely wore out a set of Pilot 2’s. They diagnosed a vibration as a bad torque converter. Luckily this forum set me straight that it was the fuel management system going in and out of 4 and 8 cylinders. A plug-in module eliminated that, but there was still a strange shimmy to the car that is now gone.
As a note to others, I also went away from the run-flat Pilot 2’s to Continental road tires which also made a huge difference in both touring and sport mode.
Bob
Bob
Received 19,854 Likes
'20-'21-'22-'23-'24
It is a shame that this problem with bent/cracked wheels is happening. Hopefully the lawsuit over this does some good for those that have had problems.
